StarTech.com Dual Drive Duplicator / Eraser
Quicklinx: D883WS00 Mfr#: SDOCK2ERU33
  • Easy drive duplication
    The dual-drive duplicator and eraser is ideal for IT professionals, such as system administrators and technicians, because it makes drive management more efficient. The drive duplicator function is effective for disk image duplication, data recovery from failing hard drives, and backing up and archiving hard drives to prevent data loss. It provides standalone sector-by-sector hard drive cloning with up to 24 GBpm or 420 MBps duplication speed. You can duplicate 2.5" or 3.5" SSDs or HDDs with ease, without connecting to a host computer.
  • Two erase modes
    The erase function helps you get the most out of your SATA drives, making it easy to re-use or re-purpose your drives. The drive eraser securely sanitizes up to two drives simultaneously, providing two modes of erasing: quick erase and secure erase. The secure erase mode provides you with the peace of mind that sensitive data has been sanitized, important to many businesses, government offices, and professional services such as legal, accounting and health care offices.
  • Transfer files quickly between the dock and your PC
    The dock also provides an external storage solution, letting you dock your drives through USB 3.0 (5 Gbps), also known as USB 3.1 Gen 1, and transfer files between a docked hard drive and a host computer. It improves your workflow by providing quick access to your hard drives, with the ability to easily swap drives in and out as needed.
  • Includes two USB cables for versatility
    The drive duplicator and eraser comes with two USB cables, for flexible use with the latest USB-C laptops and tablets, as well as legacy devices. It includes both USB-C to B and USB-A to B cables. The duplicator dock is also compatible with a Thunderbolt 3 USB-C port.
  • Designed for easy drive management
    The dual-drive duplicator/eraser features a top-loading design that makes it easy to insert your drives. It also features independent drive doors, drive controllers and power switching. The ejection buttons enable fast and simple drive removal. LED indicators display the current state of the duplication or erasure process, including the HDD status and clone or erase progress.
StarTech.com Dual Hard Drive Duplicator And Eraser - HDD sanitizer - Hard Drive Dock (SDOCK2ERU33) - solid state / hard drive duplicator/eraser
Solid state / hard drive duplicator/eraser
USB 2.0, USB 3.0
0 (installed) / 2 (max)
Supported Drives
SATA-600
Duplication Speed
24 GBpm
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
AC 120/230 V
14.7 cm x 13 cm x 6.8 cm
1.125 kg
Duplication Speed
24 GBpm
Chassis
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-600
Storage
HDD Array External Interface
USB 2.0, USB 3.0
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
2
Hard Drive
No HDD
Expansion Bays
2 (total) / 2 (free) x external - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B , 2 x SATA 6Gb/s - 22 pin Serial ATA
UASP transfer protocol, S.M.A.R.T. support, TRIM support, Quick Erase, Secure Erase
1 x USB-C to USB 3.0 type B cable , 1 x USB 3.0 to USB 3.0 type B cable
MTBF
10,000 hours
FCC, RoHS, WEEE, RCM
External power adapter
AC 120/230 V
Power Provided
36 Watt
14.7 cm
13 cm
6.8 cm
1.125 kg
5 °C
35 °C
20 - 80%
D883 StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed In Stock £287.21
D883 StarTech.com USB 3.0 Standalone Eraser Dock In Stock £209.69
D883 StarTech.com Hard Disk Drive Duplicator Dock In Stock £80.83
D883 StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn In Stock £234.88
