StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI
Quicklinx: D385WS00 Mfr#: DK30A2DH
Add dual monitors (two 4K Ultra HD), multiple USB ports, GbE, and audio to your laptop, using this universal USB-C and USB 3.0 dock. This dual-4K USB 3.0 docking station is the next generation in USB universal docking stations, working with both USB-C and USB-A port equipped laptops and supporting multiple combinations of Ultra HD 4K DisplayPort and HDMI monitors.
It's Mac and Windows compatible, making it the ideal accessory for your MacBook Pro, Dell XPS or other laptop.
This dual-4K docking station helps improve your productivity by expanding the display capabilities of your laptop across two Ultra HD 4K monitors - even if your laptop doesn't natively support 4K output. The docking station supports 4K low latency, high-resolution graphics on both video ports, using any combination of HDMI or DisplayPort monitors.
With the dual-4K dock, you can connect: 2x 4K DisplayPort displays at 4096 x 2160 resolution @ 60Hz / 3840 x 2160 @ 60Hz; 2x 4K HDMI displays at 4096 x 2160 resolution @ 60Hz / 3840 x 2160 @ 60Hz; 1x 4K DisplayPort + 4K HDMI displays at 4096 x 2160 resolution @ 60Hz / 3840 x 2160 @ 60Hz.
The docking station is ideal for producers, graphic and web designers, engineers, architects and many other professionals who work on advanced graphics applications. It offers a fast and easy way to maximize your laptop's workable screen space, giving you three screens in total when coupled with your laptop's display.
Compatible with both Windows and MacBook computers, this universal laptop dock supports DisplayLink technology and works with USB-C and USB-A enabled laptops. This means you can connect newer USB-C or Thunderbolt 3 laptops or extend the life of legacy USB 3.0 (Type-A) laptops. DisplayLink graphics technology works across computing platforms and connector types to provide a universal multi-display docking solution. The USB-C connector works seamlessly with DisplayLink to support high-resolution monitors, enabling two full 4Kp60 displays from a single USB connection.
With its universal interface, the docking station can enable a single desktop setup to support different users at different times, no matter what type of computer or device is being used. The universal docking station allows one docking station to be used throughout the organization, for use with the latest Ultrabook and MacBook laptops, and Windows Pro tablets as well as older devices.
Providing both full backward compatibility and future proofing, it is the ultimate docking station solution for offices with mixed laptop deployment.
This USB 3.0 docking station lets you connect the peripherals you need, to transform your laptop into a powerful, fully capable workstation. With six USB 3.0 ports (USB Type-A), a Gigabit Ethernet port, plus separate 3.5 mm audio and microphone ports for multiple audio, you have all the connections you need to maximize performance.
To add laptop charging support for USB-C-equipped laptops, simply add the StarTech.com HB30C1A1CPD USB to USB-C adapter to extend this dock's versatility.
  • Enhance Productivity with Dual-4K 60Hz Video
    Ideal for highly detailed graphics applications, this dual-4K 60Hz docking station enhances your productivity?by expanding the display capabilities of your laptop across two Ultra HD 4K monitors.?The laptop docking station works with DisplayLink ?to support high-resolution monitors, enabling two full 4K 60Hz displays from a single USB connection. With the dual-4K dock, connect: • 2x 4K DisplayPort displays (up to 4096 x 2160p @ 60Hz) • 2x 4K HDMI displays (up to 4096 x 2160p @ 60Hz) • 1x 4K DisplayPort + 4K HDMI displays (up to 4096 x 2160p @ 60Hz)
  • Connects to USB-C and USB-A Laptops
    The USB 3.0 docking station supports USB-C and USB-A enabled Mac and Windows laptops. This means you can connect newer USB-C or Thunderbolt 3 laptops or extend the life of legacy USB 3.0 (Type-A) laptops.
  • All the Connections You Need
    This USB-A & USB-C dock lets you transform your Mac or Windows laptop into a full workstation with six USB 3.0 (Type-A) ports, a Gigabit Ethernet port, and separate 3.5 mm audio and microphone ports for multiple audio connections, all using a single cable. DK30A2DH is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com Dual 4K Dock - Mac and Windows - USB-A & USB-C - DP & HDMI (DK30A2DH) - docking station - USB-C / Thunderbolt 3 - 2 x HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
2 x HDMI
8.34 cm x 22.39 cm x 2.71 cm
430 g
Black & silver
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO, DK30ADD, SVA20N2NEUA, TB33A1C
Docking station
8.34 cm
22.39 cm
2.71 cm
430 g
Enclosure Colour
Black & silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
2 x display / video - DisplayPort input - 20 pin DisplayPort , 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 6 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x audio - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm
1 x USB-C to USB-A cable - external , 1 x USB-C cable - external
LED indicator, full duplex support
RoHS, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol)
Power adapter
AC 120/230 V
Microsoft Windows XP 32-bit, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Ubuntu 20.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
D385 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
D385 StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £3.62
D385 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
D385 StarTech.com Monitor Mount - USB Passthrough In Stock £161.64
D385 StarTech.com Dual Monitor Mount - Stackable In Stock £217.58
D385 StarTech.com Dual Monitor Stand In Stock £82.12
D385 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
D385 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
D385 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.46
D385 StarTech.com Vertical Dual Monitor Stand In Stock £80.40
D385 StarTech.com Vertical Dual Monitor Mount In Stock £68.85
D385 StarTech.com USB 3.0 Dual Monitor Dock In Stock £104.35
D385 StarTech.com Thin Client Mount - VESA In Stock £23.04
D385 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
D385 StarTech.com USB C Dock DP 4K30Hz or VGA In Stock £82.39
D385 StarTech.com USB-C KVM Docking Station In Stock £241.11
