DUAL-LAPTOP KVM DOCK: connect / toggle between 2 PCs on your desktop and share 2 4K 60Hz displays, keyboard, mouse and other USB peripherals; toggle between two laptops using a toggle button on the front of the dock.
SIMULTANEOUSLY CHARGE TWO LAPTOP COMPUTERS: The USB-C KVM dock charges the 2 PCs connected via USB-C (PD 3.0); The included 180W power adapter automatically provides 90W of power to the active host and 45W of power to the standby host.
GUARANTEED COMPATIBILITY: DisplayLink-certified dual-host KVM dock supports 2x displays on MacBooks M1/M2; Works with mixed OS (Win/MacOS/Chrome OS); Works with PC USB-C, TB4/3, USB-A (USB-C to A cable not included).
CONNECTIVITY: The dock features a variety of ports for device connectivity; 2x USB 2.0 Type-A HID/2x USB-A (10Gbps)/USB-C (10Gbps)/2x DisplayPort/2x USB-C/Gigabit Ethernet/audio stereo 3.5mm/micro 3.5mm host ports/2x K-Slots (Standard/Nano).
OUR ADVANTAGE: Connectivity tools included for IT pros and IT teams with Network MAC Address Pass-Through for network security, WiFi Auto Switching to improve network performance/USB Event Monitoring/Windows Layout.
DisplayLink certified
The docking station is DisplayLink certified, for Plug and Display compatibility with Windows, ChromeOS and macOS. The KVM docking station enables separate operating systems to be used on the connected host devices, making it possible to use and switch, for example, between a Windows and a Mac laptop. DisplayLink technology also supports extended dual displays on Apple MacBook M1/M2s, which are not natively capable of handling more than one external display. DisplayLink certification guarantees easy connectivity to the docking station and multi-display configuration, with support for resolutions up to 4K 60Hz on both external displays. Perfect for software developers and IT technicians who need access to multiple platforms for testing, or for content creators who use more than one system for different tasks. -
Dual Power Delivery for laptops
The KVM docking station supports Power Delivery 3.0 and charges both connected computers via USB-C. The docking station supplies 90 W of power to the active host computer and 45 W of power to the second computer. This means that both laptops can be charged simultaneously and quickly, enabling users to keep their devices powered up all day long. Power Delivery eliminates the need for separate charging cables, reducing desktop clutter and simplifying the workspace. -
Complete docking station
Connect two USB-C computers to this docking station to access a wide range of port connectivity, options and features from both computers. The docking station offers the following features: - 2x DisplayPort ports for dual-display output with support for resolutions up to dual 4K 60Hz. - 2x USB-A (USB 2.0 480Mbps) HID ports for USB peripherals, such as keyboard and mouse. - 2x USB-A and 1x USB-C (USB 3.2 Gen 2 10Gbps) ports for connecting high-speed USB peripherals, such as SSD storage. - 1x Gigabit Ethernet port with WoL (Wake-on-LAN) for wired LAN connection. - 1x 3-position 3.5 mm TRRS jack for stereo audio output. - 1x 2-position 3.5 mm microphone jack for mono audio input. - 2x K-Slots (regular/nano) to attach the docking station with a locking cable (sold separately) for security. This docking station is designed with a mounting scheme that allows it to be mounted with StarTech.com mounting accessories (sold separately). With our mounting accessories, the docking station can easily be attached to the VESA pattern on the back of a monitor or to any flat surface, providing a clutter-free workspace. The mounting pattern guarantees secure attachment, and accessories are easy to install. The following brackets are compatible with this product: - SSPMSUDWM - Surface bracket for docking station - SSPMSVESA - VESA bracket for docking station -
Improve productivity and device management with the StarTech.com Connectivity Tools application
Developed to enhance performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of computer connectivity accessories. The software suite includes : -Text | Advanced Window Layout Utility: Configure and save customized window layouts. -Text | Mac Address Transfer Utility: Enhance network security. -Text | USB Event Monitoring Utility: Track and record connected USB devices. - Text | Wi-Fi Auto-Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
- StarTech.com Dual-Laptop USB-C KVM Docking Station, Dual Monitor 4K 60Hz DisplayPort Dock, 5-Port USB Hub, GbE, 90W/45W Power Delivery to Two Laptops, Windows/Mac, 2-Host KVM Dock - docking station - USB-C 3.2 Gen 2 - 2 x DP - 1GbE - TAA Compliant
- Product Type
- Docking station
- Docking Interface
- USB-C 3.2 Gen 2
- Video Interfaces
- 2 x DP
- 9 cm x 22.4 cm x 4 cm
- 402 g
- Localisation
- United Kingdom, Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter 180 Watt AC 100-240 V (DC 20 V)
- TAA Compliant
- 3-year warranty
- Product Type
- Docking station
- 9 cm
- 22.4 cm
- 4 cm
- 402 g
- Localisation
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 2 x USB 2.0 - 4 pin USB Type A , 2 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x microphone - mini-phone 3.5 mm , 1 x headphones - mini-phone 3.5 mm , 2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x USB-C 3.2 Gen 2 with Power Delivery 3.0 - 24 pin USB-C
- Cables Included
- 2 x USB-C cable - external - 1 m
- Security lock slot (cable lock sold separately), LED indicator, dual display support, full duplex support, MAC address pass-through, plastic housing, up to 10Gbps data transfer, host selection button, dual KVM host devices, 90W power delivery for active host device, 45W power delivery for standby host device
- Security Slot Type
- Kensington nano security slot / Kensington security slot
- RoHS, WEEE, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0, DisplayLink certified
- TAA Compliant
- Power Device
- Power adapter
- Power Consumption (Max)
- 180 Watt
- Voltage Required
- AC 100-240 V
- Voltage Provided
- DC 20 V
- OS Required
- Google Chrome OS, Ubuntu 18.04, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Ubuntu 20.04, Apple macOS Monterey 12.0, Microsoft Windows 10 / 11, Apple macOS Ventura 13.0, Ubuntu 22.04, Apple macOS Sonoma 14.0
- Limited warranty - 3 years
- Shipping Width
- 16 cm
- Shipping Depth
- 28.5 cm
- Shipping Height
- 9 cm
- Shipping Weight
- 1.8 kg
- -10 °C
- 45 °C
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.74 |
StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla | In Stock | £9.06 |
StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA | In Stock | £14.35 |
StarTech.com 3ft/1m USB-C Cable with USB-A Adapter - Hybrid USB C Cable | In Stock | £21.96 |
