StarTech.com USB 3.0 Dual Monitor Dock
Quicklinx: D5G6WS00 Mfr#: DK30ADD
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Silver/Black
16 In Stock
£101.81 ex VAT
£122.17 inc VAT
Expand your laptop connectivity by adding two displays, with HDMI and DVI or HDMI and VGA, plus six USB ports and a Gigabit Ethernet port, all through a single USB 3.0 port. This USB 3.0 dual-monitor docking station lets you add the ports you need to your laptop, to maximize your workstation performance. The laptop dock provides a cost-effective universal docking solution, with support for HDMI and DVI monitors and plenty of connection options for peripherals.
The versatile laptop docking station enables you to improve your efficiency and productivity by expanding the display capabilities of your Windows laptop or MacBook. Set up dual displays by connecting to one HDMI and one DVI monitor. Plus, the dock includes a DVI to VGA adapter, so you can connect your legacy VGA monitor in place of a DVI monitor.
With the dual-monitor dock, you can connect: 1x HDMI display + 1x DVI display at 2048 x 1152 resolution @ 60Hz; 1x HDMI display at 2048 x 1152 resolution + 1x VGA display at 1920 x 1200 resolution @ 60Hz.
The USB 3.0 docking station offers a fast and easy way to maximize your laptop's workable screen space, giving you three screens in total when coupled with your laptop's display.
This USB docking station lets you easily connect your keyboard, external drives and other peripherals, to transform your laptop into a powerful, fully capable workstation. The dock features a USB Type-B dock connection (host) for more robust port stability, unlike the Micro-B ports that are often used on other docking stations. From the single USB 3.0 host connection, the dock provides six USB 3.0 (Type-A) ports, a Gigabit Ethernet port, plus a 3.5 mm audio headphone port. Two of the USB 3.0 ports are always-on fast-charging ports, adding charge-and-sync flexibility for up to two mobile devices.
The compact, horizontal design of the laptop docking station makes it easy to position on your desk, alongside your other devices and peripherals. It's an attractive addition to any workspace, with a sleek silver and black finish that matches most laptops.
  • Enhance Productivity with Dual Video
    The USB 3.0 dock expands the display capabilities of your?Mac or Windows laptop.?Set up dual displays by connecting to one HDMI and one DVI monitor. Plus, the laptop docking station includes a DVI to VGA adapter, so you can connect to a legacy VGA monitor.
  • With the dual-monitor dock, you can connect:
    • 1x HDMI display + 1x DVI display at 2048 x 1152 resolution @ 60Hz • 1x HDMI display at 2048 x 1152 resolution + 1x VGA display at 1920 x 1200 resolution @ 60Hz
  • All the Connections You Need
    Transform your laptop into a fully capable workstation. This USB 3.0 dock provides six USB 3.0 (Type-A) ports so you can easily connect your keyboard, external drives and other peripherals, from the single USB 3.0 host connection. Two of the USB 3.0 ports are always-on fast-charge ports, adding charge-and-sync flexibility for up to two mobile devices. The docking station also provides a Gigabit Ethernet port plus a?3.5 mm audio headphone port. DK30ADD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com USB 3.0 Docking Station, Dual Monitor Laptop Docking Station with HDMI & DVI/VGA Video, 6-port USB 3.1 Gen 1 5Gbps Hub, GbE, Audio, Universal USB Type-A Dock, Windows & Mac - Dual Display Dock (DK30ADD) - docking station - USB - DVI, HDMI - 1GbE
Docking station
Docking Interface
USB
Video Interfaces
DVI, HDMI
8.62 cm x 21.61 cm x 3.12 cm
291 g
Black & silver
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
P/N: DK30A2DH, SVA20N2NEUA
Docking station
8.62 cm
21.61 cm
3.12 cm
291 g
Enclosure Colour
Black & silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
1 x display / video - DVI-Analog/Digital (dual link) - 24+5 pin combined DVI , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x headphone/microphone combo jack - mini-phone 3.5 mm 4-pole
1 x DVI-VGA adapter - external , 1 x SuperSpeed USB cable - external - 1 m
Wake on LAN, LED indicator, DisplayLink DL-3900 chipset, full duplex support
FCC, RoHS, DisplayLink Plug and Display, USB Battery Charging Specification Rev. 1.2
Power adapter
AC 120/230 V
Apple MacOS X 10.10 - 10.12, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
D5G6 StarTech.com USB 3.0 Dual Monitor Dock In Stock £101.81
Device Type: Laptop
