Product
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket
Quicklinx: 92P6WS00 Mfr#: BRACKET25X2
Type: Storage bay adapter
11 in stock
£7.38 ex VAT
£8.85 inc VAT
Express delivery Delivered on Tuesday
Mount two 2.5in SATA SSDs/HDDs into a single 3.5in drive bay. The BRACKET25X2 Dual hard drive mounting bracket kit enables you to maximize the internal mounting space of your computer, by installing two 2.5in SATA hard drives (HDD) or solid state drives (SSD) into a single 3.5in mounting bay. The bracket can be used with IDE drives using the 2.5in to 3.5in IDE Hard Drive cable adapter (IDE4044).
For a hassle-free installation, the hard drive mounting kit includes all required data and power cabling for both SATA drives.
The BRACKET25X2 features solid steel construction.
StarTech.com Dual 2.5" SATA Hard Drive to 3.5" Bay Mounting Bracket - storage bay adapter
Storage bay adapter
Steel
Supported Form Factor
3.5" to 2.5"
Expansion Bays
2 x internal - 2.5"
Compatible Bay
1 3.5"
10.2 cm x 11.6 cm x 2.2 cm
150 g
Storage bay adapter
3.5" to 2.5"
Steel
Bays
2 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
1 x Serial ATA power Y cable , 1 x Serial ATA cable
RoHS
Limited warranty - lifetime
10.2 cm
11.6 cm
2.2 cm
150 g
92P6 StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £1.59
92P6 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £3.38
92P6 StarTech.com 12in Latching SATA Cable In Stock £3.33
92P6 StarTech.com 24in Latching SATA Cable In Stock £4.46
92P6 StarTech.com 40 Pin Female IDE to SATA Adapter Converter In Stock £10.82
92P6 StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £3.41
92P6 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.38
Price Range Ex VAT: 0 - 50
