StarTech.com DP 1.4 to Dual HDMI MST Hub
Quicklinx: GTBNWS00 Mfr#: MST14DP122HD
£31.07 ex VAT
£37.28 inc VAT
This DisplayPort to HDMI MST Hub drives two 4K 60Hz HDMI monitors from a DisplayPort enabled Windows device.
  • Multi-tasking Made Easy
    This DisplayPort to HDMI video splitter allows you to connect up to two additional displays in extended or mirror mode. Connecting two independent 4K 60Hz displays creates high-performance workstations for users in your organization, enabling easier multi-tasking, resulting in increased productivity.
  • 4K at 60Hz and HDR
    Native support for MST, on any Windows device, enables an easy set up. This MST Hub separates the single stream into two independent signals, one for each HDMI enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity.
  • Hassle-Free Setup
    MST offers an easy setup, by natively working on any Windows device. Plug-and-play installation with no drivers or software required. A 12in (30cm) attached cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this dual-monitor splitter is USB powered (USB Cable included). MST14DP122HD is backed by a StarTech.com 3-year warranty, and a lifetime of free, North American based, multilingual technical support.
StarTech.com DP to Dual HDMI MST HUB, Dual HDMI 4K 60Hz, DisplayPort Multi Monitor Adapter with 1ft (30cm) Cable, DP 1.4 Multi Stream Transport Hub, DSC | HBR3, DP to 2x HDMI Ports - DP to HDMI Splitter (MST14DP122HD) - adapter - DisplayPort / HDMI
Cable
Adapter - DisplayPort / HDMI
Max Output Resolution
3840 x 2160 - 60 Hz
Grey
Connector
DisplayPort - male
Connector (Second End)
2 x HDMI - female
DisplayPort 1.4
Display Stream Compression (DSC), HBR3 audio support, Multi Stream Transport (MST), 7.1 channel Surround Sound
3-year warranty
Cable Type
Adapter
Interface Supported
DisplayPort / HDMI
DisplayPort 1.4
Grey
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Microsoft Windows 10 / 11
Connector
20 pin DisplayPort - male
2 x 19 pin HDMI Type A - female
USB power cable
RoHS
10.5 cm
4.3 cm
1.4 cm
53 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
110 g
Limited warranty - 3 years
GTBN StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £8.55
GTBN StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.55
GTBN StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.54
GTBN StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £12.23
GTBN StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.37
GTBN StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet In Stock £15.31
GTBN StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.46
GTBN StarTech.com 2-Port DisplayPort MST Hub In Stock £30.56
GTBN StarTech.com 3-Port DisplayPort MST Hub In Stock £66.26
