StarTech.com DisplayPort to HDMI Video Adapter Converter
Quicklinx: 6PFZWS00 Mfr#: DP2HDMI2
Type: DisplayPort
Length: 26.5cm
38 in stock
£12.52 ex VAT
£15.02 inc VAT
Connect your HDMI monitor or HDTV to a DisplayPort equipped computer. The StarTech.com DP2HDMI2 DisplayPort to HDMI Adapter lets you connect an HDMI-enabled display or projector to a DisplayPort out port from a computer (desktop or laptop), eliminating the expense of having to upgrade your display for DisplayPort compatibility. The adapter supports display resolutions of up to 1920x1200, allowing you to take full advantage of HDMI video capability. DP2HDMI2 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
StarTech.com DisplayPort to HDMI Adapter - 1920x1200 - HDMI Video Converter - Latching DP Connector - Monitor to HDMI Adapter (DP2HDMI2) - video adapter - DisplayPort / HDMI - 26.5 cm
Cable
Video adapter - DisplayPort / HDMI
Length
26.5 cm
Connector
DisplayPort - male
Connector (Second End)
HDMI - female
3-year warranty
P/N: DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, DK30CHDDPPD, DK30CHDPPDUE, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Cable Type
Video adapter
Interface Supported
DisplayPort / HDMI
Length
26.5 cm
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - female
FCC, RoHS
25 mm
1.4 cm
32 g
Limited warranty - 3 years
6PFZ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.52
6PFZ StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £19.63
6PFZ StarTech.com 3ft DP to HDMI cable - 4K In Stock £16.26
6PFZ StarTech.com 6 ft DP to HDMI cable - 4K In Stock £17.24
6PFZ StarTech.com DisplayPort to HDMI - 4K In Stock £14.42
6PFZ StarTech.com 5m DisplayPort to HDMI Cable - 4K In Stock £20.84
6PFZ StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.39
Type: DisplayPort
Length: 26.5cm
Price Range Ex VAT: 0 - 50
