Connect your HDMI monitor or HDTV to a DisplayPort equipped computer. The StarTech.com DP2HDMI2 DisplayPort to HDMI Adapter lets you connect an HDMI-enabled display or projector to a DisplayPort out port from a computer (desktop or laptop), eliminating the expense of having to upgrade your display for DisplayPort compatibility. The adapter supports display resolutions of up to 1920x1200, allowing you to take full advantage of HDMI video capability. DP2HDMI2 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
Convenient connection
This adapter features a male 20-pin DisplayPort connector on one end, allowing easy connection to a video source, while the female 19-pin HDMI Type-A connector on the other end connects seamlessly with HDMI displays. -
Secure fit
Equipped with a latching DP connector, this adapter ensures that the connection remains secure, reducing the likelihood of disconnection during critical tasks or presentations.
- StarTech.com DisplayPort to HDMI Adapter - 1920x1200 - HDMI Video Converter - Latching DP Connector - Monitor to HDMI Adapter (DP2HDMI2) - adapter - DisplayPort / HDMI - 26.5 cm
- Cable
- Adapter - DisplayPort / HDMI
- Length
- 26.5 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - female
- 3-year warranty
- Designed For
- P/N: DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, DK30CHDDPPD, DK30CHDPPDUE, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SV231QDPU34K, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- Cable Type
- Adapter
- Interface Supported
- Length
- 26.5 cm
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - female
- FCC, RoHS
- 25 mm
- 1.4 cm
- 32 g
- Limited warranty - 3 years
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.91 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.76 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £10.82 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.00 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £14.43 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.15 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £8.51 |
StarTech.com HDMI or DVI to DisplayPort Active Converter | In Stock | £69.12 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.26 |
StarTech.com 3ft DP to HDMI cable - 4K | In Stock | £12.87 |
StarTech.com 6 ft DP to HDMI cable - 4K | In Stock | £14.20 |
StarTech.com DisplayPort to HDMI - 4K | In Stock | £13.39 |
StarTech.com 5m DisplayPort to HDMI Cable - 4K | In Stock | £20.25 |
StarTech.com 3m DisplayPort to HDMI Cable - 4K | In Stock | £18.01 |
StarTech.com DisplayPort to HDMI - 4K 60Hz | In Stock | £21.78 |
