The HDMI2DP DVI or HDMI to DisplayPort Converter converts an HDMI, DVI or Mini DVI input signal into a DisplayPort (or Mini DisplayPort) output, eliminating the cost of upgrading your source device hardware or purchasing a new display. With support for full HD resolutions up to 1920x1200, the HDMI2DP converter is the perfect solution for connecting devices that have an HDMI, DVI single-link or mini DVI output, such as video cards (desktop or laptop), video game consoles or home theater receivers, to your DisplayPort-capable display.
- StarTech.com Active HDMI to DisplayPort Converter - 1920 x 1200 - EDID Support - HDMI or DVI to DP Converter (HDMI2DP) - video converter - black
- Video converter
- Graphics Engine
- - up to
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort output - 20 pin DisplayPort
- 4.3 cm x 8.2 cm x 2.3 cm
- Enclosure Colour
- Black
- 2-year warranty
- Designed For
- P/N: SVA5M3NEUA
- Video converter
- Max Resolution
- 1920 x 1200 at 60 Hz
- 1 x HDMI input - 19 pin HDMI Type A - female , 1 x DisplayPort output - 20 pin DisplayPort - female
- Voltage Required
- AC 120/230 V
- 5 Watt
- FCC, RoHS
- 4.3 cm
- 8.2 cm
- 2.3 cm
- 14 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 90% (non-condensing)
- Designed For
- P/N: SVA5M3NEUA
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.54 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.76 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £10.82 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £14.43 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.17 |
StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable | In Stock | £5.04 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.35 |
StarTech.com HDMI or DVI to DisplayPort Active Converter | In Stock | £69.12 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.26 |
StarTech.com DisplayPort to HDMI - 4K | In Stock | £13.39 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.95 |
StarTech.com 2 m (6.6 ft.) HDMI to DisplayPort Cable - 4K 30Hz | In Stock | £51.35 |
StarTech.com 3 m (9.8 ft.) HDMI to DisplayPort Cable - 4K 30Hz | In Stock | £56.66 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.52 |
