StarTech.com DisplayPort to HDMI Video Adapter Converter
Quicklinx: 6PFZWS00 Mfr#: DP2HDMI2
Type: DisplayPort
Length: 26.5cm
£14.43 ex VAT
£17.31 inc VAT
Connect your HDMI monitor or HDTV to a DisplayPort equipped computer. The StarTech.com DP2HDMI2 DisplayPort to HDMI Adapter lets you connect an HDMI-enabled display or projector to a DisplayPort out port from a computer (desktop or laptop), eliminating the expense of having to upgrade your display for DisplayPort compatibility. The adapter supports display resolutions of up to 1920x1200, allowing you to take full advantage of HDMI video capability. DP2HDMI2 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
  • Convenient connection
    This adapter features a male 20-pin DisplayPort connector on one end, allowing easy connection to a video source, while the female 19-pin HDMI Type-A connector on the other end connects seamlessly with HDMI displays.
  • Secure fit
    Equipped with a latching DP connector, this adapter ensures that the connection remains secure, reducing the likelihood of disconnection during critical tasks or presentations.
StarTech.com DisplayPort to HDMI Adapter - 1920x1200 - HDMI Video Converter - Latching DP Connector - Monitor to HDMI Adapter (DP2HDMI2) - adapter - DisplayPort / HDMI - 26.5 cm
Cable
Adapter - DisplayPort / HDMI
Length
26.5 cm
Connector
DisplayPort - male
Connector (Second End)
HDMI - female
3-year warranty
P/N: DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, DK30CHDDPPD, DK30CHDPPDUE, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SV231QDPU34K, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Cable Type
Adapter
Interface Supported
DisplayPort / HDMI
Length
26.5 cm
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - female
FCC, RoHS
25 mm
1.4 cm
32 g
Limited warranty - 3 years
6PFZ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.91
6PFZ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.76
6PFZ StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.82
6PFZ StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.00
6PFZ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.43
6PFZ StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.17
6PFZ StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.51
6PFZ StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £69.12
6PFZ StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.26
6PFZ StarTech.com 3ft DP to HDMI cable - 4K In Stock £12.87
6PFZ StarTech.com 6 ft DP to HDMI cable - 4K In Stock £14.20
6PFZ StarTech.com DisplayPort to HDMI - 4K In Stock £13.39
6PFZ StarTech.com 5m DisplayPort to HDMI Cable - 4K In Stock £19.94
6PFZ StarTech.com 3m DisplayPort to HDMI Cable - 4K In Stock £18.01
6PFZ StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £21.78
Type: DisplayPort
Length: 26.5cm
