StarTech.com DisplayPort to DVI Active Adapter
Quicklinx: 7NXJWS00 Mfr#: DP2DVIS
Length: 20cm
More than 50 in stock
£21.76 ex VAT
£26.11 inc VAT
The DP2DVIS DisplayPort to DVI Active Single Link adapter lets you connect your DisplayPort video source (desktop PC, laptop, etc.) to a DVI-D monitor, projector or display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a DisplayPort-capable monitor. Unlike passive adapters, this DP to DVI converter offers an active conversion for use with any DisplayPort output - ideal for graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity). Supporting resolutions up to 1920x1200, this compact device provides a simple solution for converting DisplayPort output for compatibility with existing DVI monitors, televisions or projectors.
StarTech.com DisplayPort to DVI Active Adapter - DisplayPort adapter - 20 cm
DisplayPort adapter
HDCP compliant
Length
20 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - female
FCC, RoHS
P/N: MSTMDP123DP
DisplayPort adapter
HDCP compliant
Length
20 cm
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - female
DisplayPort 1.1a, FCC, RoHS
P/N: MSTMDP123DP
7NXJ StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.77
7NXJ StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.55
7NXJ StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
7NXJ StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
7NXJ StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.89
7NXJ StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £18.34
7NXJ StarTech.com DisplayPort to DVI Active Adapter In Stock £21.76
Length: 20cm
Price Range Ex VAT: 0 - 50
