StarTech.com DisplayPort to DVI Video Adapter Converter
Quicklinx: 6NZNWS00 Mfr#: DP2DVI2
More than 50 In Stock
£9.00 ex VAT
£10.80 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVI2 DVI/DisplayPort adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI2 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
  • Reliable connection
    Equipped with a latching DP connector, this adapter ensures that the connection remains secure, minimizing the risk of accidental disconnections during use.
  • High-resolution support
    Supports video resolutions up to 1920 x 1200, allowing for clear and detailed image quality, perfect for both business presentations and multimedia viewing.
  • Versatile compatibility
    Designed with a male 20 pin DisplayPort and a female 24 + 5 pin DVI connector, this adapter works seamlessly with a range of devices, providing flexibility in connectivity.
  • Compact design
    The lightweight and portable nature of this adapter makes it an ideal accessory for users on the go, enabling quick connections without hassle.
  • Environmentally compliant
    This adapter meets both FCC and RoHS standards, ensuring that it adheres to strict safety and environmental regulations for peace of mind.
StarTech.com DisplayPort to DVI-D Adapter - 1920x1200 - Passive DVI Video Converter with Latching DP Connector (DP2DVI2) - DisplayPort adapter - 15.2 cm
DisplayPort adapter
Length
15.2 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-I - female
FCC, RoHS
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
DisplayPort adapter
Length
15.2 cm
Connector
20 pin DisplayPort - male
24+5 pin combined DVI - female
FCC, RoHS
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
6NZN StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
6NZN StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.26
6NZN StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £23.94
6NZN StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.00
6NZN StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £5.59
6NZN StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.17
6NZN StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.52
6NZN StarTech.com DisplayPort to DVI Active Adapter In Stock £20.81
6NZN StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £11.84
6NZN StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £18.47
6NZN StarTech.com 3ft DP to DVI Converter Cable In Stock £14.55
6NZN StarTech.com mDP to Dual-Link DVI Adapter In Stock £17.48
