StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600
Quicklinx: 8G54WS00 Mfr#: DP2DVID2
20 In Stock
£41.39 ex VAT
£49.66 inc VAT
Connect your DVI Dual Link display to a DisplayPort video source, for high resolution applications. The DP2DVID2 DisplayPort to DVI (Dual-Link) Adapter actively converts the output signal from a DisplayPort video source for use with a DVI-D display (monitor, etc.) or projector, helping to eliminate the equipment costs of upgrading a DVI display to a newer model for the sake of compatibility.
The adapter supports high resolution video (up to 2560x1600), maintaining the outstanding graphical performance from a DisplayPort-equipped desktop video card, laptop or MacBook.
DP2DVID2 performs an active DisplayPort-DVI conversion that is suitable for video sources that output either multimode (DP++) or single-mode DisplayPort signals. This ensures the adapter can be used even with graphics cards that aren't capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
StarTech.com DisplayPort to DVI Adapter - Dual-Link - Active DVI-D Adapter for Your Monitor / Display - USB Powered - 2560x1600 (DP2DVID2) - DisplayPort / DVI adapter - 37 cm
USB power, active adapter, 2560 x 1600 (WQXGA) support, plastic housing, HBR2 support
Length
37 cm
Connectors
20 pin DisplayPort - male , 4 pin USB Type A (power only) - male
Connectors (Second End)
24+1 pin digital DVI - female
USB 2.0 / DisplayPort 1.2
3-year warranty
Length
37 cm
6.4 cm
5.49 cm
2.2 cm
160 g
Connectors
USB 2.0 / DisplayPort 1.2, FCC, RoHS, EDID compatible, HDCP
Shipping Width
17.4 cm
Shipping Depth
14.3 cm
Shipping Height
3.5 cm
Shipping Weight
232 g
3-year warranty
8G54 StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.80
8G54 StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
8G54 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
8G54 StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £5.79
8G54 StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.38
8G54 StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
8G54 StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £41.39
8G54 StarTech.com 3ft DP to DVI Converter Cable In Stock £16.64
8G54 StarTech.com mDP to Dual-Link DVI Adapter In Stock £17.94
