The DP2DVIS DisplayPort to DVI Active Single Link adapter lets you connect your DisplayPort video source (desktop PC, laptop, etc.) to a DVI-D monitor, projector or display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a DisplayPort-capable monitor. Unlike passive adapters, this DP to DVI converter offers an active conversion for use with any DisplayPort output - ideal for graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity). Supporting resolutions up to 1920x1200, this compact device provides a simple solution for converting DisplayPort output for compatibility with existing DVI monitors, televisions or projectors.
- StarTech.com DisplayPort to DVI Adapter - Active Conversion - 1920x1200 - DP to DVI Single Link Converter for DVI-D Display (DP2DVIS) - DisplayPort adapter - 20 cm
- HDCP compliant
- Length
- 20 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-D - female
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: DK30C2DAGPD, DKWG30DPHPD, DKWG30DPHPDU, MST30C2DPPD, SP123DP, TB32DP14, TB32DP2T, TB3CDK2DP, TB3CDK2DPUE, TB3CDOCKDP, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB3DKM2DP, TB3DKM2DPL
- HDCP compliant
- Length
- 20 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 24+1 pin digital DVI - female
- DisplayPort 1.1a, FCC, RoHS
- 3-year warranty
- Designed For
StarTech.com 6 ft DVI-D Single Link Cable - M/M | In Stock | £6.86 |
StarTech.com 15 ft DVI-D Single Link Cable - M/M | In Stock | £13.72 |
StarTech.com 6 ft DVI-D Dual Link Cable - M/M | In Stock | £6.78 |
StarTech.com 10 ft DVI-D Dual Link Cable - M/M | In Stock | £10.72 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £15.63 |
StarTech.com DisplayPort DVI Video Adapter Converter | In Stock | £13.69 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.18 |
StarTech.com 10 ft DVI-D Single Link Cable - M/M | In Stock | £7.98 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £18.55 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.04 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £95.60 |
StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £21.64 |
StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £24.75 |
StarTech.com 3ft DP to DVI Converter Cable | In Stock | £15.43 |
