Replace your lost or failed power adapter. This 12V DC power supply can provide a power source for any electronic device that has an M-type barrel and requires 12volts and up to 2amps of power. The power supply is a perfect replacement for the lost or damaged 12-volt 2-amp power adapter you've used to power your existing electronics. When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
Efficient power supply
This power adapter is engineered to provide a steady and reliable power supply with an output voltage of 12 V and a maximum current of 2 A, suitable for a range of devices. -
Wide compatibility
With an input voltage range of AC 100-240 V, this adapter is compatible with various electrical systems, allowing for versatile use in different locations. -
Compliance with standards
The StarTech.com DC Power Adapter adheres to important standards including UL, FCC, RoHS, WEEE, and RCM, ensuring it meets safety requirements and promotes environmental sustainability. -
User-friendly design
Featuring an external form factor, this power adapter can be easily transported and connected to devices, providing convenience for users at home or on-the-go.
- StarTech.com DC Power Adapter - 12V, 2A - Universal Replacement Power Adapter (NA, EU, UK, AU) (SVA12M2NEUA) - power adapter
- Power adapter - external
- Localisation
- Australia, North America, United Kingdom, Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Included Accessories
- Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (NA)
- 2-year warranty
- Designed For
- P/N: ET10GSFP, ET91000SM10, ET91000SM20, HB30A3A1CST, HB30C3A1CST, IES101G2SFPW, IES81GW, RKPNLLT, S351BMU33ET, S351BMU33ETG, SDOCKU33EF, ST121HDBTDK, ST121HDBTL, ST121HDWP, ST12MHDLAN4R, SV231DPDDUA2, SV231DVGAU2A, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA2, SV431DVGAU2A, USB312SAT3, USB31C2SAT3
- Localisation
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Max Electric Current
- 2 A
- UL, FCC, RoHS, WEEE, RCM
- Limited warranty - 2 years
- Designed For
- P/N: 110VDSLEXT, 110VDSLEXTEU, 110VDSLEXTGB, AP150WN1X1OD, AP150WN1X1OE, EOC1110K, EOC1110R, ET1000S40LC2, ET10GSFP, ET90110SC2, ET90110SM302, ET90110ST2, ET90110WDM2, ET91000LC2, ET91000LCOAM, ET91000SC2, ET91000SFP2, ET91000SM10, ET91000SM20, ET91000SM402, HB30A3A1CST, HB30C3A1CST, IES101G2SFPW, IES81GW, IM12D1500P, IREXT2, MCM110SC2, MCM110SC2EU, MCM110SC2GB, MCM110SC2P, MCM110ST2, MCM110ST2EU, MCM110ST2GB, NETRS2321P, R300WN22GA, R300WN22GAEU, RKPNLLT, S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, SATDOCKU3S, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, ST1212T, ST1214T, ST1216PRO, ST1218T, ST121EXT, ST121HDBT5, ST121HDBTDK, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121HDFXA, ST121HDWP, ST121R, ST121SHD50, ST121UTP, ST121UTPEP, ST121UTPHD2, ST122DVIA, ST122HDMI2, ST122PROA, ST122UTPA, ST122UTPAL, ST122VGAU, ST124DVIA, ST124HDMI2, ST124UTPEA, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4R, ST12MHDLANRX, ST222MXA, ST224MX, ST424MX, STUTPEALR, STUTPWALLA, SV1631DUSB, SV1631DUSBU, SV231DD2DUA, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV231DPUA, SV231DVGAU2A, SV231DVIUA, SV231DVIUAHR, SV231HDMIUA, SV231QDVIUA, SV231TDVIUA, SV431DD2DUA, SV431DDVDUA, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV431DUSBU, SV431DVGAU2A, SV431TDVIUA, SV441DUSBI, SV565DUTPU, SV565FXDUSA, SV565UTPUL, SV831DUSB, SV831DUSBU, SV831DUSBUK, SV841HDIE, SV841HDIEGB, USB312SAT3, USB31C2SAT3, VS221HDQ, VS222HDQ, VS420RDVIA, VS440HDMI, VS721MULTI
StarTech.com VGA to Cat 5 Monitor Extender Kit (250ft/80m) - VGA Cat5 Extender | In Stock | £119.00 |
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £233.24 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £243.20 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £114.49 |
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £40.39 |
StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub | In Stock | £153.35 |
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £240.14 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £128.11 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £189.49 |
StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft | In Stock | £288.51 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £89.31 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £452.75 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.65 |
StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier | In Stock | £68.05 |
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub | In Stock | £124.31 |
StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £142.79 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £273.74 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £309.46 |
StarTech.com 4 Port VGA Over CAT5 Video Extender - 450ft (150m) | In Stock | £114.62 |
StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m | In Stock | £149.37 |
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £145.25 |
StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps | In Stock | £308.76 |
StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter SC 2 km | In Stock | £69.74 |
StarTech.com 10/100 Mbps Single Mode Fiber Media Converter SC 30 km | In Stock | £129.48 |
StarTech.com USB Dual VGA over Cat5 KVM Console Extender - 650 ft / 200m | In Stock | £336.25 |
StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) | In Stock | £183.25 |
StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) | In Stock | £90.68 |
StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP | In Stock | £37.71 |
StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) | In Stock | £310.26 |
StarTech.com 2 Port HDMI Switch w/ Automatic and Priority Switching - 1080p | In Stock | £55.88 |
StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p | In Stock | £81.48 |
StarTech.com 2-port Dual VGA KVM Switch | In Stock | £67.05 |
StarTech.com DC Power Adapter - 9V, 2A | In Stock | £12.31 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.95 |
StarTech.com GbE Fiber Media Converter 10km | In Stock | £179.13 |
StarTech.com GbE Fiber Media Converter 20km | In Stock | £162.84 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £245.82 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.71 |
StarTech.com DC Power Adapter - 5V, 2A | In Stock | £9.67 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £34.51 |
StarTech.com HDBaseT Extender - 4K | In Stock | £290.19 |
StarTech.com ST12MHDLAN4K Receiver | In Stock | £253.06 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £40.15 |
