StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m)
Quicklinx: 90WVWS00 Mfr#: ST121SHD50
Type: Misc
16 In Stock
£92.94 ex VAT
£111.52 inc VAT
Extend HDMI up to 165ft (50m) over Cat5e/6 cabling with Power over Cable to Receiver. The ST121SHD50 HDMI over Cat5e/Cat6 Video Extender kit lets you extend HDMI video and audio by up to 165 feet (50 Meters) over dual Cat5e cables, or 130 feet (40 Meters) over dual Cat6 cables. For added versatility the kit features Power Over Cable and only requires a single power adapter that can be connected to either the Transmitter or Receiver.
With support for High-Definition resolutions of up to 1920x1080 / 1080p and the accompanying digital audio, this cost-effective HD extender can easily be installed using new or existing Ethernet infrastructure wiring. For a convenient plug-and-play installation, the HDMI extender features built-in EDID monitor emulation, which ensures native resolution and maximum compatibility with your display or projector.
For added flexibility and convenience, HDMI cables up to 32ft (10m) can be connected to both the local and remote units, which lets you extend your HDMI signal to even further distances.
The HDMI extender kit offers a point-to-point digital signage solution right out of the box, including both local transmitter and remote receiver units, along with optional hardware that lets you mount the units as needed. Plus, with Power Over Cable, you can easily extend an HDMI signal in areas where access to power outlets is limited.
  • Reliable video transmission
    This extender supports up to 1080p resolution, ensuring clear and high-quality video playback for presentations, home theaters, and more.
  • Flexible installation options
    Equipped with a mounting kit, this extender allows for convenient setup in various environments, whether on a wall or desk.
  • Wide operating range
    Designed to operate efficiently under a temperature range of 0°C to 40°C, this extender is suitable for cooled and heated spaces.
  • Humidity resilience
    With an operating humidity range of 0 to 80%, this device can function effectively in various conditions, making it ideal for diverse locations.
  • Compliant and safe
    This product meets FCC and RoHS standards, ensuring it adheres to safety regulations while being environmentally friendly.
StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 165 ft (50m) HDMI Video/Audio Over Dual Ethernet Cable Extender (ST121SHD50) - video/audio extender
Video/audio extender
External
North America, United Kingdom, Europe
Transmission Medium
CAT 5e/6
Max Transfer Distance
50 m
AC 120/230 V
5.1 cm x 8 cm x 2.1 cm
157 g
P/N: ST128HDMI2, SVA12M2NEUA, SVA12M5NA, VIDWALLMNT
External
Wired
Max Resolution
1920 x 1080 / 1080p
50 m
Status Indicators
1 x video - HDMI - 19 pin HDMI Type A
Mounting Kit
Included
FCC, RoHS
External power adapter
AC 120/230 V
5.1 cm
8 cm
2.1 cm
157 g
0 - 80%
90WV StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
90WV StarTech.com 75 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £25.96
90WV StarTech.com 75ft Orange Cat6 Patch Cable In Stock £25.91
90WV StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £18.33
90WV StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.35
90WV StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £187.84
90WV StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £92.94
90WV StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.78
90WV StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) In Stock £318.01
90WV StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £50.75
90WV StarTech.com HDMI over CAT6 with USB - 50m In Stock £167.96
90WV StarTech.com 3-Port HDBaseT Extender Kit In Stock £436.66
90WV StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
90WV StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
90WV StarTech.com 4K 60Hz HDBaseT extender - 70m (100m @ 1080) In Stock £383.53
90WV StarTech.com HDMI over CAT6 Extender In Stock £107.55
90WV StarTech.com HDMI over CAT6 Extender - 4K 60Hz - 330ft / 100m -IR Support In Stock £331.68
Type: Misc
