StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD
Quicklinx: 7P38WS00 Mfr#: SV431DUSBU
Type: KVM switch
Connectivity: KVM
Ports: 4
19 In Stock
£164.74 ex VAT
£197.68 inc VAT
This 4-port USB KVM Switch lets you control multiple USB based computers from a single console (USB keyboard, USB mouse, monitor).
The versatile USB KVM switch features convenient pushbutton and hot-key control for quick, reliable switching between connected computers.
A convenient and straight-forward control solution, the USB KVM switch supports both manual and auto-scan modes and simple configuration through the built-in OSD.
Designed to ensure maximum space-efficiency, the USB KVM switch features a slim 1U design that fits neatly into a server equipment rack/cabinet (with options mounting bracket) and offers rear cable connections to eliminate cable tangles.
StarTech.com 4-Port USB KVM Swith with OSD - TAA Compliant - 1U Rack Mountable VGA KVM Switch (SV431DUSBU) - KVM switch - 4 ports
KVM switch - 4 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
4 x KVM port(s)
KVM Users Qty
1 local user
On-Screen Display
AC 120/230 V
22 cm x 13 cm x 4.3 cm
1.5 kg
3-year warranty
P/N: IM12D1500P, RACKCOND17HD, RKCONS1701, SV431RACK, SVA12M2NEUA, SVA12M5NA, SVECONUS10, SVECONUS15, SVECONUS6, SVUSBVGA10, SVUSBVGA6
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
4 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
On-Screen Display
Status Indicators
Port status, power
4 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
External power adapter
AC 120/230 V
Rack Mounting Kit
Optional
FCC, RoHS
22 cm
13 cm
4.3 cm
1.5 kg
Limited warranty - 3 years
5 °C
7P38 StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £7.06
7P38 StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £10.60
7P38 StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £15.89
7P38 StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £94.41
7P38 StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £25.12
7P38 StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD In Stock £164.74
7P38 StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £7.94
7P38 StarTech.com DC Power Adapter - 9V, 2A In Stock £12.06
7P38 StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
7P38 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
Type: KVM switch
Connectivity: KVM
Ports: 4
