The QSFP-40GE-LR4-ST is a Cisco QSFP-40GE-LR4 compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-LR4 compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Cisco QSFP-40GE-LR4 Compatible QSFP+ Module, 40GBASE-LR4, 40GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 40GE Gigabit Ethernet QSFP+ LC 10km, 1270nm to 1330nm, DDM - Lifetime Warranty (QSFP-40GE-LR4-ST) - QSFP+ transceiver module - 40GbE
- QSFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 40GBase-LR4
- Data Transfer Rate
- 40 Gbps
- Optical Wave Length
- 1270-1330 nm
- Data Link Protocol
- 40GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Cisco QSFP-40GE-LR4
- 12.2 cm x 1.83 cm x 0.85 cm
- 49 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 40GBase-LR4
- 40GbE
- 40 Gbps
- 1270-1330 nm
- 10 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 40GBase-LR4 - LC single-mode female x 2
- MTBF
- 244,610,583 hours
- MSA
- 1.3 Watt
- 12.2 cm
- 1.83 cm
- 0.85 cm
- 49 g
- Shipping Width
- 12 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 3.5 cm
- Shipping Weight
- 60 g
- Limited warranty - lifetime
