This Thunderbolt to Ethernet 10G adapter is a robust and durable solution for IT professionals looking to add an RJ45 port to their Thunderbolt-enabled computer. This adapter supports multi-gigabit speeds, including 10/5/2.5/1Gb/s and 100Mb/s Base-T speeds. In addition, 10GBASE-T and 5GBASE-T/2.5GBASE-T (NBASE-T) capabilities ensure compatibility with the latest network switches and access points.
10GbE Network Speeds
A Thunderbolt 3 to RJ45 is the ideal accessory for bandwidth-intensive tasks, server maintenance, high-performance storage, or streaming online content. The adapter is powered by the Marvell AQC107S, providing high-speed 10GbE speeds and supports plug-and-play in Windows and macOS for straightforward deployment. -
Quiet and Compact Design
This Thunderbolt 3 NIC is a portable and convenient peripheral for on-the-go users with a footprint of just 4.27x2.9x1.14in (108.5x75x29.1mm). The aluminum chassis utilizes passive cooling for noiseless operation. Activity and computer link LEDs provide status at a glance. The Thunderbolt to NIC adapter includes a certified 27.5in (70cm) Thunderbolt 3 cable, which ensures maximum performance on Thunderbolt 3 and 4 computers. This TAA-compliant Thunderbolt 3 NIC is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
- Startech Thunderbolt 3 to Ethernet Adapter, 10GbE, Multi-Gigabit, Thunderbolt 3 to RJ45 Network Adapter, 10GBASE-T/5-2.5GBASE-T NIC, TB3/TB4 10G Network Adapter w/ TB3-Certified Cable, TB3 10GbE, Win/Mac (TB310G2) - network adapter - Thunderbolt 3 - 1/2.5/5/10GBase-T x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- Thunderbolt 3
- Ports
- 10.8 cm 2.9 cm
- 500 g
- Cabling Type
- Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
- Data Link Protocol
- 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
- Data Transfer Rate
- 40 Gbps
- Capacity
- Jumbo frame size: 16000
- Processor
- Intel / Alpine Ridge / Marvell JHL6340 / AQC107S
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz
- Space grey
- System Requirements
- Linux LTS versions only, Microsoft Windows 10 / 11, Ubuntu Linux 20.04 or later, Apple macOS 10.15 / 11.0 / 12.0 / 13.0
- 2-year warranty
- Network adapter
- Form Factor
- External
- Thunderbolt 3
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
- 40 Gbps
- Capacity
- Status Indicators
- Link/activity, connection status
- Auto-negotiation
Processor / Memory
- Processor
- 1 x 10GBase-T - RJ-45 - female , 1 x Thunderbolt 3 - 24 pin USB-C - female
- Cables Included
- 1 x Thunderbolt 3 / USB-C cable (external)
- Space grey
- OS Required
- 10.8 cm
- 2.9 cm
- 500 g
- Limited warranty - 2 years
- 35 °C
- 55 °C
- 20 - 80% (non-condensing)
