StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC
Quicklinx: 82HKWS00 Mfr#: SFPC1110
Type: Modules
20 In Stock
£37.28 ex VAT
£44.73 inc VAT
Add support for 1000 Mbps RJ45 copper Ethernet connections to networking equipment with spare SFP slots. The SFPC1110 Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module (Mini-GBIC) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a copper Ethernet port on your 1000 Base-T networking equipment.
Featuring Digital Diagnostics Monitoring support and 1000 Mbps Auto-negotiation at distances up to 100m (330 feet), this Ethernet SFP module can be installed into any fiber networking devices with an MSA or Cisco compliant SFP port. Delivering convenience and scalability, this copper transceiver is fully hot-pluggable, allowing you to install the module without interrupting network traffic or requiring a device reboot. This SFP module is compatible with the Cisco SFP-GE-T transceiver.
  • Reliable connectivity
    The SFP module utilizes Ethernet 1000Base-TX technology, ensuring dependable wired connections for various networking applications.
  • Operational temperature range
    This module functions within a temperature range of 0°C to 70°C, making it suitable for diverse environments and applications.
  • High data transfer rate
    Support for a data transfer rate of 1 Gbps facilitates efficient data communication across the network.
  • Easy integration
    The RJ-45 connector provides straightforward integration into existing network infrastructures without the need for additional equipment.
  • Compliant with industry standards
    Meets FCC, RoHS, and MSA standards, ensuring safety and reliability for consistent performance in various networking environments.
StarTech.com Cisco SFP-GE-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 10/100/1000 Mbps, RJ-45 (Copper) 100m, Cisco IE3400, IE3300, IE3200, 1000MbE Mini GBIC Transceiver - Lifetime Warranty (SFPC1110) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-TX
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
0.9 cm x 5.5 cm x 1.4 cm
25 g
P/N: MCM1110SFP
Plug-in module
Wired
Cabling Type
1000Base-TX
1GbE
Data Transfer Rate
1 Gbps
100 m
Auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x Ethernet 1000Base-TX - RJ-45
Compatible Slots
1 x SFP (mini-GBIC)
FCC, RoHS, MSA
0.9 cm
5.5 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
P/N: MCM1110SFP
82HK StarTech.com Gb MM SFP Fiber Transceiver In Stock £35.04
82HK StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.13
82HK StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC In Stock £37.28
82HK StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £139.16
82HK StarTech.com Fiber Media Converter - Open In Stock £42.26
82HK StarTech.com Gb RJ45 Copper SFP - 10 Pack In Stock £230.69
82HK StarTech.com Gigabit RJ45 Copper SFP In Stock £38.33
82HK StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £320.87
82HK StarTech.com Cisco GLC-TE Compatible SFP Copper Module - 1000BASE-T In Stock £44.74
Type: Modules
