StarTech.com Gb RJ45 Copper SFP - 10 Pack
Quicklinx: C190WS00 Mfr#: GLCT10PKST
Type: Transceiver
Hurry, only 3 left in stock!
£237.16 ex VAT
£284.59 inc VAT
Maximize cost-savings and performance with this bulk pack of RJ45 Mini-GBIC modules. Perfect for large-scale deployments or installations on multiple devices, this bulk pack of Gigabit RJ45 Copper SFP modules provides maximum cost savings. Built to exacting specifications and fully tested to ensure maximum performance, these high-quality transceiver modules can be installed into Cisco switches and routers that support the GLC-T SFP transceiver module, as well as other major brands of networking equipment.
The SFP transceivers provide a dependable and cost-effective way to add, replace or upgrade the copper Ethernet ports on your 1000Base-T networking equipment.
The SFP transceivers included in this 10-pack are manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
These Gigabit RJ45 SFPs are engineered to the highest quality standards and are 100% Cisco compatible, equivalent to the Cisco GLC-T SFP transceiver. StarTech.com transceivers are configured and fully tested to ensure they work seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, these SFP transceiver modules are fully hot-pluggable, which enables you to install them without interrupting network traffic or having to reboot your equipment. They provide a convenient solution that's compatible with a multitude of multi and single-port Gigabit Ethernet networking devices.
Ideal for use in switches, routers and other networking equipment, the SFPs provide reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFPs support auto-negotiation, a maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
You can count on GLCT10PKST for reliable performance.
  • Efficient connectivity
    This SFP transceiver module is designed for effective Gigabit Ethernet communication, providing a data transfer rate of 1.25 Gbps for reliable network performance.
  • Robust compliance standards
    Meets various compliance standards, including FCC, RoHS, WEEE, and MSA, ensuring regulatory adherence and quality assurance.
  • Versatile operating temperature
    Can operate in a range of temperatures from 0°C to 70°C, making it suitable for diverse environmental conditions.
  • Advanced features
    Incorporates auto-negotiation and auto-uplink capabilities, allowing seamless integration and connectivity in different network setups.
  • Extended transfer distance
    Enables data transmission over a maximum distance of 100 m, supporting versatile networking applications.
StarTech.com Cisco GLC-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, Cisco Firepower, ASR920, IE2000, Mini GBIC Transceiver - Lifetime Warranty (GLCT10PKST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Packaged Quantity
10 (specifications are for single item)
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1.25 Gbps
1GbE
Max Transfer Distance
100 m
Cisco GLC-T
1.2 cm x 6.8 cm x 1.4 cm
25 g
Packaged Quantity
Plug-in module
Silver
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1.25 Gbps
100 m
Auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 female
FCC, RoHS, WEEE, MSA
Cisco GLC-T
1.2 cm
6.8 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
C190 StarTech.com Gb MM SFP Fiber Transceiver In Stock £36.36
C190 StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £32.38
C190 StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC In Stock £37.94
C190 StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £146.68
C190 StarTech.com Fiber Media Converter - Open In Stock £44.55
C190 StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £338.20
Type: Transceiver
