The GLCTEST is a Cisco GLC-TE compatible copper transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers for extended temperatures. It delivers dependable 1 GbE connectivity over copper cable, for 1000BASE-T compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Reliable connectivity
Equipped with a data transfer rate of 1 Gbps, this module ensures high-speed communication for demanding networking tasks. -
Versatile compatibility
Designed with an RJ-45 connector, this module is compatible with a variety of devices, allowing for flexible integration into existing networks. -
Robust environmental resilience
Operating effectively in a wide temperature range of -40°C to 85°C, the module is suitable for deployment in challenging environments. -
Long-lasting performance
The MTBF of 4,655,371 hours means this module is built to withstand extensive use, reducing the need for frequent replacements. -
Easy installation
The hot swap feature allows for simple module replacement without powering down the equipment, minimizing downtime during maintenance.
- StarTech.com Cisco GLC-TE Compatible Module, 1000BASE-T Copper Industrial Gigabit Ethernet Transceiver, SFP to RJ45 Cat6/Cat5e 100m Extended Temp, Cisco Firepower, IE 2000, C9500, C2960 - Lifetime Warranty (GLCTEST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 100 m
- OEM Manufacturer Equivalent Part Number
- Cisco GLC-TE
- 1.4 cm x 6.5 cm x 1.2 cm
- 72 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-T
- 1GbE
- 1 Gbps
- 100 m
- Full duplex capability, hot swap module replacement
- IEEE 802.3
- 1 x Ethernet 1000Base-T - RJ-45
- MTBF
- 4,655,371 hours
- FCC, RoHS, WEEE, REACH, MSA
- Cisco GLC-TE
- 1.4 cm
- 6.5 cm
- 1.2 cm
- 72 g
- Limited warranty - lifetime
- -40 °C
- 85 °C
- 30 - 75%
StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £31.13 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £139.16 |
StarTech.com Fiber Media Converter - Open | In Stock | £42.26 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £320.87 |
