Add support for 1000 Mbps RJ45 copper Ethernet connections to networking equipment with spare SFP slots. The SFPC1110 Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module (Mini-GBIC) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a copper Ethernet port on your 1000 Base-T networking equipment.
Featuring Digital Diagnostics Monitoring support and 1000 Mbps Auto-negotiation at distances up to 100m (330 feet), this Ethernet SFP module can be installed into any fiber networking devices with an MSA or Cisco compliant SFP port. Delivering convenience and scalability, this copper transceiver is fully hot-pluggable, allowing you to install the module without interrupting network traffic or requiring a device reboot. This SFP module is compatible with the Cisco SFP-GE-T transceiver.
- StarTech.com Cisco SFP-GE-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 10/100/1000 Mbps, RJ-45 (Copper) 100m, Cisco IE3400, IE3300, IE3200, 1000MbE Mini GBIC Transceiver - Lifetime Warranty (SFPC1110) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-TX
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 100 m
- 0.9 cm x 5.5 cm x 1.4 cm
- 25 g
- Limited lifetime warranty
- Designed For
- P/N: MCM1110SFP
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-TX
- 1GbE
- 1 Gbps
- 100 m
- Auto-negotiation, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x Ethernet 1000Base-TX - RJ-45
- Compatible Slots
- 1 x SFP (mini-GBIC)
- FCC, RoHS, MSA
- 0.9 cm
- 5.5 cm
- 1.4 cm
- 25 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- Designed For
- P/N: MCM1110SFP
StarTech.com Gb MM SFP Fiber Transceiver | In Stock | £42.40 |
StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £36.45 |
StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC | In Stock | £37.51 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £160.53 |
StarTech.com Fiber Media Converter - Open | In Stock | £48.69 |
StarTech.com Gigabit RJ45 Copper SFP | In Stock | £41.04 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £368.50 |
StarTech.com Cisco GLC-TE Compatible SFP Copper Module - 1000BASE-T | In Stock | £48.76 |
