The FAN1156PWM CPU Cooler with PWM Cooling Fan for Socket LGA1156/1155 systems provides reliable and efficient cooling for compatible Intel Core i3/i5/i7 CPUs. With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
- Startech 95mm CPU Cooler Fan with Heatsink for Socket LGA1156/1155 - w/ Pulse Width Modulation (PWM) (FAN1156PWM) - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA1156 Socket, LGA1155 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 95 mm
- Fan Height
- 25 mm
- Fan Bearing
- Ever Lubricate bearing
- Rotation Speed
- 1000-3000 rpm
- Air Flow
- 65.6 cfm
- Noise Level
- 33 dBA
- Power Connector
- 4-pin fan connector
- 9.5 cm x 9.5 cm x 4.5 cm
- 297 g
- 2-year warranty
- Product Type
- Processor cooler
- 9.5 cm
- 9.5 cm
- 4.5 cm
- 297 g
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core i3 , Core i7 , Core i5
- Heatsink Material
- Aluminium
- Heatsink Dimensions
- 95 mm x 95 mm x 20 mm
- Fan Diameter
- 95 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 1000-3000 rpm
- Air Flow
- 65.6 cfm
- Noise Level
- 33 dBA
- Power Connector
- MTBF
- 40,000 hour(s)
- RoHS
- Limited warranty: - 2 years
- -20 °C
- 70 °C
