StarTech.com 20g Tube CPU Thermal Paste Grease Compound for Heatsinks
Quicklinx: 7TX9WS00 Mfr#: HEATGREASE20
Type: Other
£5.24 ex VAT
£6.28 inc VAT
Improve the Heat Transfer between a CPU and Heatsink through a Ceramic/Silicone Compound. The HEATGREASE20 CPU Thermal Paste Compound can be used to improve the effectiveness of a CPU cooler, by thermally bonding the surface of the CPU to the heatsink, which enables the heatsink and fan to work more efficiently to remove harmful heat from the CPU.
This 20g tube of ceramic-based thermal grease is enough for a large number of CPU installations for most home or business computers or any other light application where good thermal bonding between two surfaces is required.
  • Effective thermal conductivity
    With a thermal conductivity of 1.066 W/mK, this thermal paste enhances heat dissipation, helping to maintain optimal processor temperatures.
  • Wide temperature range
    This thermal compound operates effectively in a temperature range from -20°C to 100°C, ensuring reliability in various conditions.
StarTech.com 20g Tube CPU Thermal Paste Grease Compound for Heatsinks - heat grease - cpu paste - thermal compound (HEATGREASE20) - processor heatsink paste
Processor heatsink paste
7.2 cm x 3 cm x 1.8 cm
24 g
P/N: FAN1156PWM
7.2 cm
3 cm
1.8 cm
24 g
Thermal Conductivity
1.066 W/mK
Limited warranty: - 2 years
-20 °C
100 °C
P/N: FAN1156PWM
7TX9 StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube for Heatsink In Stock £4.56
Type: Other
