StarTech.com 60x65mm Socket A CPU Cooler Fan with Heatsink for AMD Duron or Athlon
Quicklinx: 403DWS00 Mfr#: FANDURONTB
Type: Heatsink
£8.68 ex VAT
£10.41 inc VAT
This entry-level heatsink is specifically designed for AMD Athlon and Duron processors. This heatsink with fan provides enough cooling power for most Athlon and Duron CPUs without costing a fortune. It is suitable for Duron CPUs up to 1300 MHz, Thunderbird Athlon CPUs up to 1333 MHz and Athlon XP CPUs up to 2000+ MHz.
StarTech.com 60x65mm Socket A CPU Cooler Fan with Heatsink for AMD Duron or Athlon (FANDURONTB) - processor cooler
Processor cooler
Compatibility
Socket A
Fan Diameter
60 mm
Fan Height
20 mm
Rotation Speed
4000 rpm
Air Flow
23.2 cfm
Noise Level
31 dBA
Power Connector
3-pin plug
Ball bearing
Processor cooler
Heatsink & Fan
Compatible With
Socket A
Heatsink Dimensions
62.5 mm x 60 mm x 40 mm
Thermal Resistance
0.64 °C/W
Fan Diameter
60 mm
Fan Height
20 mm
Rotation Speed
4000 rpm
Air Flow
23.2 cfm
Noise Level
31 dBA
Power Connector
3-pin plug
Ball bearing
Limited warranty: - 2 years
403D StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube for Heatsink In Stock £4.59
403D StarTech.com 95mm CPU Cooler Fan with Heatsink for Socket LGA1156/1155 with PWM In Stock £14.06
Type: Heatsink
