StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep
Quicklinx: 6B9XWS00 Mfr#: RK812WALLO
Product Type: Rack, Rack
£68.51 ex VAT
£82.21 inc VAT
This 8U Open Frame Wall Mount Equipment Rack is a high quality, low cost relay rack that is easy to assemble and install into any environment. The rack can be wallmounted or installed as a free standing storage solution.
Able to accommodate common data, audio-video and telecom equipment, the open rack offers a depth of 12in; the wall mounts are positioned 16in apart (center to center), making it suitable for mounting on virtually any wall surface, based on North American wall frame stud spacing standards.
StarTech.com 8U 19" Wall Mount Network Rack - 12" Deep 2 Post Open Frame Server Room Rack for Data/AV/IT/Computer Equipment/Patch Panel with Cage Nuts & Screws 135lb Capacity, Black (RK812WALLO) - rack - 8U
Rack
Rack Size
19"
Height (Rack Units)
8U
Product Material
Steel
50.5 cm x 30.8 cm x 35.6 cm
8 kg
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
Rack
Product Material
Steel
Rack Size
19"
Height (Rack Units)
8U
50.5 cm
30.8 cm
35.6 cm
8 kg
Weight Limit
80 kg
UL, RoHS
Limited warranty: - 1 year
6B9X StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
6B9X StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
6B9X StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
6B9X StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
6B9X StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £49.48
6B9X StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
6B9X StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
6B9X StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
6B9X StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
6B9X StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
6B9X StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £363.55
6B9X StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
6B9X StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
6B9X StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
6B9X StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
6B9X StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
6B9X StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
6B9X StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.48
6B9X StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
6B9X StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
6B9X StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
6B9X StarTech.com Portable Server Rack - 9U In Stock £267.95
6B9X StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
6B9X StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
6B9X StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.81
6B9X StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
6B9X StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
6B9X StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
6B9X StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
6B9X StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
6B9X StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £514.25
6B9X Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
6B9X StarTech.com 19in Cable Management Panel In Stock £24.18
6B9X StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
6B9X StarTech.com 26U Server Rack Enclosure In Stock £475.05
6B9X StarTech.com 9U Wall-Mount Rack Cabinet In Stock £178.89
6B9X StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
6B9X StarTech.com 12U Server Rack Enclosure In Stock £338.60
6B9X StarTech.com 12U Server Rack Enclosure In Stock £283.26
6B9X StarTech.com 15U Server Rack Enclosure In Stock £320.92
6B9X StarTech.com 12U Server Rack Enclosure In Stock £385.18
6B9X StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £29.04
6B9X StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
6B9X StarTech.com 42U Server Rack Cabinet In Stock £1,258.59
Product Type: Rack
Product Type: Rack
