Add 7 external, USB 3.0 ports to a computer from a single USB connection. The ST7300USB3B USB 3.0 Hub lets you add seven external USB 3.0 ports to a computer from a single USB 3.0 host connection.
Offering data transfer rates up to 5 Gbps, the USB hub meets SuperSpeed USB 3.0 specifications and is backward compatible with USB 2.0 and 1.x devices.
Designed for easy port access when connecting or disconnecting devices, the hub features one-sided port orientation, with current overload detection and protection across all seven ports. The hub supports Plug-and-Play and Hot-Swap technologies, letting you switch and operate your connected devices without having to power down the host computer.
The USB hub is bus powered for use in environments where a power outlet may be unavailable, but is perfect for high-power USB devices when used with the included optional power adapter.
Efficient connectivity
The 7 Port USB 3.0 Hub offers a seamless connection experience, allowing users to expand their desktop's USB capabilities with up to 7 additional USB 3.0 ports. This ensures a high-speed data transfer rate of up to 5 Gbps, making it suitable for high-bandwidth devices. -
Universal compatibility
Designed to support a broad range of devices, this hub is compatible with both Mac and PC. Its Plug-and-Play functionality, coupled with FCC and RoHS compliance, ensures a reliable and hassle-free connection for all your USB devices. -
Durable design
Built to withstand the rigors of daily use, the hub operates efficiently across a wide range of environmental conditions, from 5 - 95% humidity and temperatures as low as -2°C to as high as 52°C. This durability ensures your hub remains operational in various settings, providing consistent performance.
- StarTech.com 7 Port USB 3.0 Hub - Up To 5 Gbps - 7 x USB - Universal Multi Port USB Extender for Your Desktop - USB Powered (ST7300USB3B) - hub - 7 ports
- Hub - 7 ports
- Subtype
- USB
- Ports
- 7 x SuperSpeed USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- 20.9 cm x 10.5 cm x 3.5 cm
- 140 g
- Black
- System Requirements
- Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Windows 8 (32/64 bits), Apple MacOS X 10.x, Linux 2.6.x
- 2-year warranty
- Designed For
- P/N: 2SD4FCRU3, BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S42, SDMSDRWU3AC, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3LA, UUSBHAUB6IN
- Hub - 7 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Status Indicators
- Power
- 7 x USB 3.0 Type A , 1 x USB 3.0 Type B
- Power Device
- External power adapter
- Black
- Plug and Play, FCC, RoHS
- OS Required
- 20.9 cm
- 10.5 cm
- 3.5 cm
- 140 g
- Limited warranty - 2 years
- -2 °C
- 52 °C
- 5 - 95%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 56 °C
- Designed For
- P/N: 2SD4FCRU3, BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S42, SDMSDRWU3AC, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £100.50 |
StarTech.com 3m USB 3.0 Active Extension Cable - M/F | In Stock | £72.50 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £39.74 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £52.91 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £49.11 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £40.89 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £64.50 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £113.49 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £133.39 |
StarTech.com 7 Port Compact USB 3.0 Hub | In Stock | £46.47 |
StarTech.com 4 Port Portable USB 3.0 Hub | In Stock | £24.96 |
StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £31.93 |
