StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0
Quicklinx: 87PQWS00 Mfr#: ST7320USBC
Type: USB Hub
Interface: SuperSpeed USB 3.0, USB 2.0
Speed: [N/A]
Ports: 6
Form Factor: External
£38.96 ex VAT
£46.75 inc VAT
Add 2x USB 3.0 and 4x USB 2.0 ports to a computer, externally through a single USB 3.0 connection. The ST7320USBC 6-Port USB 3.0/2.0 Combo Hub features a special high-output dedicated charging port which enables you to charge USB devices by providing up to 2A of power, or it can add 2x USB 3.0 and 4x USB 2.0 ports to a computer through a single USB 3.0 host connection.
The hub includes an external power adapter, which when connected enables charging some portable electronic devices (e.g. an iPhone or other Smartphone), even without a USB connection to a host computer.
Offering a unique design that features USB ports along 3 sides of the hub, as well as a combination of USB 2.0 and 3.0 ports, this versatile and flexible USB hub is ideal for both laptop and desktop computers.
  • Versatile connectivity options
    This hub includes both two SuperSpeed USB 3.0 ports and four USB 2.0 ports, allowing for efficient connection of multiple devices simultaneously.
  • Reliable power management
    Equipped with an external power adapter, this USB hub ensures stable and consistent power supply to all connected devices.
  • Eco-friendly compliance
    The product meets FCC and RoHS standards, highlighting its commitment to environmental safety and user well-being.
  • Sleek desktop form factor
    The compact and stylish design fits seamlessly into any workspace, making it a convenient choice for home and office use.
  • Operational efficiency
    Designed to function in a wide temperature range of 0°C to 85°C, this hub is reliable across various environments and usage scenarios.
StarTech.com 7 Port USB Hub - 2 x USB 3A, 4 x USB 2A, 1 x Dedicated Charging Port - Multi Port Powered USB Hub with 20W Power Adapter (ST7320USBC) - hub - 6 ports
Hub - 6 ports
Subtype
USB
Ports
2 x SuperSpeed USB 3.0 + 4 x USB 2.0
AC 120/230 V
6 cm x 9.9 cm x 2 cm
75.4 g
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.2 - 10.6
P/N: FCREADMICRO3, MSDREADU2OTG, MSDREADU3CA, SDMSDRWU3AC, USB221SS, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Hub - 6 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Status Indicators
4 x USB 2.0 Type A , 2 x USB 3.0 Type A , 1 x USB 3.0 Type B
External power adapter
AC 120/230 V
1 x SuperSpeed USB cable
FCC, RoHS
6 cm
9.9 cm
2 cm
75.4 g
85 °C
5 - 90%
Min Storage Temperature
-10 °C
Max Storage Temperature
95 °C
87PQ StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £38.00
87PQ StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £19.33
87PQ StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White In Stock £19.33
87PQ StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.75
87PQ StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £24.95
87PQ StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
87PQ StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
87PQ StarTech.com USB 3.0 Network Adapter-Silver In Stock £23.74
87PQ StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £64.21
87PQ StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £44.32
87PQ StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £56.18
87PQ StarTech.com USB to Ethernet Adapter - 1Gb In Stock £19.76
Type: USB Hub
Interface: USB 2.0
Speed: [N/A]
Ports: 6
