Add four external USB 3.0 ports to your notebook or Ultrabook with a slim, portable hub. The ST4300MINU3W Portable 4 Port SuperSpeed Mini USB 3.0 Hub (White) lets you expand your USB connectivity by turning a single USB 3.0 port into four external USB 3.0 ports. The integrated cable design makes this mini USB hub the perfect accessory for your Mac / PC notebook or Ultrabook computer.
The 4 Port USB 3.0 hub supports USB 3.0 data bandwidth (5 Gbps - up to 10x more than USB 2.0) and is backward compatible with USB 2.0 and 1.1 devices, ensuring flawless performance from all of your USB peripherals/devices, regardless of their age.
Ideal for home and business users who require portability, the external USB 3.0 hub is USB-powered and features a rugged, compact design with a built-in cable so no additional cables are needed to connect the hub to your system.
Compact design
The compact design of this USB hub makes it easy to integrate into any workspace while minimizing cable clutter. -
Versatile compatibility
This hub supports various USB standards, ensuring it works with a wide array of devices, including those that require USB 1.1 and USB 2.0. -
Convenient powered option
The USB-powered feature allows for greater flexibility, enabling users to connect multiple devices without needing additional power sources. -
Reliable environmental performance
Designed to operate within a wide temperature range, this hub is suitable for use in different settings, ensuring longevity and reliable performance. -
User-friendly indicators
The power status indicator provides clear feedback on the hub's operation, making it easy to monitor device connectivity.
- StarTech.com 4 Port USB 3.0 Hub - Multi Port USB Hub w/ Built-in Cable - Powered USB 3.0 Extender for Your Laptop - White (ST4300MINU3W) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered
- USB 1.1, USB 2.0, USB 3.0
- 3.9 cm x 7.6 cm x 1.4 cm
- 38 g
- White
- System Requirements
- Apple MacOS X 10.0 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: FCREADMICRO3, MSDREADU2OTG, MSDREADU3CA
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- Status Indicators
- Power
- 4 x USB 3.0 Type A , 1 x USB 3.0 Type A
- White
- Cables Included
- 1 x USB cable - 14.5 cm
- FCC, RoHS
- OS Required
- 3.9 cm
- 7.6 cm
- 1.4 cm
- 38 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £38.36 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White | In Stock | £19.33 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £20.43 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £30.12 |
