Add seven USB 3.0 (5Gbps) ports to your MacBook, using this silver, Apple style hub with an extended-length cable. This compact, 7-port USB 3.0 hub is tailored to match the stylish design of your MacBook. It features a sleek, silver sandblasted housing that looks great next to your Apple laptop. And, because the hub is designed with a solid-aluminum casing, it provides the lightweight durability that's ideal for either travel or desktop usage.
This high-quality, Apple style USB hub gives you an easy way to expand your MacBook connectivity. It provides seven USB 3.0 (also known as USB 3.1 Gen 1) hub ports in a compact housing. With more ports, you have more scalability to connect extra USB devices. Plus, you can leave your devices plugged in, so they're ready to use when you need them.
The 7-port USB 3.0 hub offers a silver sandblast finish that provides a unique and stylish appearance, making the hub look as trendy and contemporary as your MacBook, Ultrabook, or laptop.
The hub features a built-in, 98 cm (38 in) cable that is longer than what most traditional hubs offer. The extended-length cable gives you the flexibility to place the hub and your devices exactly where you want them, and it ensures the hub can connect to your laptop or tablet regardless of where the laptop's USB 3.0 port is located.
This compact hub features seven ports with plenty of space between each port, unlike some USB 3.0 hubs that jam multiple ports into a tightly-packed space which makes it difficult to connect multiple devices to adjacent hub ports. With extra port spacing, you can connect devices and cables that have larger connectors, without sacrificing the hub's small footprint design.
The rugged aluminum housing offers dependable protection, so the hub is perfect for travel, such as back-and-forth trips from home to office. Plus, the compact hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
The easy-to-use hub is plug-and-play and hot-swap compatible, so you can install it quickly, with no additional drivers or software required. It includes a power adapter as well, so you can rest assured that you can connect virtually any USB 3.0 peripheral, even devices with high power requirements. Plus, you can also avoid the nuisance and cost of purchasing new devices by using the USB 3.0 hub with your current USB 2.0 and 1.x devices.
Compact design
The compact design of the 7 Port USB Hub makes it an excellent choice for limited desk space while providing ample connectivity options. -
Efficient power supply
Equipped with a 20W power adapter, ensuring all connected devices receive sufficient power for stable operation. -
Hot-plug convenience
Hot-plug functionality allows for easy connection and disconnection of devices without powering down the hub. -
Safe environmental compliance
This USB hub complies with multiple standards including FCC, RoHS, and WEEE, showcasing its environmental friendliness. -
Versatile compatibility
Designed for Mac systems, ensuring a wide range of compatibility with various devices and peripherals.
- StarTech.com 7 Port Compact USB 3.0 Hub with Built-in Cable - Aluminum USB Hub - Silver USB3 Hub with 20W Power Adapter (ST73007UA) - USB peripheral sharing switch - 7 ports
- Subtype
- USB
- Ports
- 7 x SuperSpeed USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 120/230 V 1.5 A
- 3.6 cm x 18.3 cm x 1.8 cm
- 132 g
- White, silver
- Localisation
- Australia, North America, United Kingdom, Europe
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Processor
- 1 x Genesys Logic GL3520
- Status Indicators
- Port status
- 7 x USB 3.0 Type A , 1 x USB 3.0 Type A
- Power Device
- External power adapter - hot-plug
- Installed Qty
- 1
- Voltage Required
- AC 120/230 V
- Electric Current Required
- 1.5 A
- 20 Watt
- White, silver
- Cables Included
- 1 x SuperSpeed USB cable - 98 cm
- Plug and Play, FCC, RoHS, WEEE, RCM
- Localisation
- 3.6 cm
- 18.3 cm
- 1.8 cm
- 132 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £20.94 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £48.45 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £67.46 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.01 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £30.59 |
StarTech.com 3Pt Portable USB 3.0 Hub + GbE | In Stock | £35.58 |
StarTech.com 7 Port Compact USB 3.0 Hub | In Stock | £45.43 |
StarTech.com 4 Port Portable USB 3.0 Hub | In Stock | £24.39 |
StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £31.05 |
