StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 9KRVWS00 Mfr#: ST7300USB3B
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 7
Form Factor: External
  • Windows 8 (32/64 bits)
£48.45 ex VAT
£58.14 inc VAT
Add 7 external, USB 3.0 ports to a computer from a single USB connection. The ST7300USB3B USB 3.0 Hub lets you add seven external USB 3.0 ports to a computer from a single USB 3.0 host connection.
Offering data transfer rates up to 5 Gbps, the USB hub meets SuperSpeed USB 3.0 specifications and is backward compatible with USB 2.0 and 1.x devices.
Designed for easy port access when connecting or disconnecting devices, the hub features one-sided port orientation, with current overload detection and protection across all seven ports. The hub supports Plug-and-Play and Hot-Swap technologies, letting you switch and operate your connected devices without having to power down the host computer.
The USB hub is bus powered for use in environments where a power outlet may be unavailable, but is perfect for high-power USB devices when used with the included optional power adapter.
  • Efficient connectivity
    The 7 Port USB 3.0 Hub offers a seamless connection experience, allowing users to expand their desktop's USB capabilities with up to 7 additional USB 3.0 ports. This ensures a high-speed data transfer rate of up to 5 Gbps, making it suitable for high-bandwidth devices.
  • Universal compatibility
    Designed to support a broad range of devices, this hub is compatible with both Mac and PC. Its Plug-and-Play functionality, coupled with FCC and RoHS compliance, ensures a reliable and hassle-free connection for all your USB devices.
  • Durable design
    Built to withstand the rigors of daily use, the hub operates efficiently across a wide range of environmental conditions, from 5 - 95% humidity and temperatures as low as -2°C to as high as 52°C. This durability ensures your hub remains operational in various settings, providing consistent performance.
StarTech.com 7 Port USB 3.0 Hub - Up To 5 Gbps - 7 x USB - Universal Multi Port USB Extender for Your Desktop - USB Powered (ST7300USB3B) - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
20.9 cm x 10.5 cm x 3.5 cm
140 g
Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Windows 8 (32/64 bits), Apple MacOS X 10.x, Linux 2.6.x
P/N: 2SD4FCRU3, BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S42, SDMSDRWU3AC, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3LA, UUSBHAUB6IN
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Status Indicators
7 x USB 3.0 Type A , 1 x USB 3.0 Type B
External power adapter
Plug and Play, FCC, RoHS
20.9 cm
10.5 cm
3.5 cm
140 g
-2 °C
52 °C
5 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
56 °C
P/N: 2SD4FCRU3, BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S42, SDMSDRWU3AC, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
9KRV StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £103.00
9KRV StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.26
9KRV StarTech.com 3m USB 3.0 Active Extension Cable - M/F In Stock £69.06
9KRV StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £84.93
9KRV StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.96
9KRV StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £24.95
9KRV StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £19.39
9KRV StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
9KRV StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £39.78
9KRV StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
9KRV StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £108.59
9KRV StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £128.27
9KRV StarTech.com 7 Port Compact USB 3.0 Hub In Stock £45.43
9KRV StarTech.com 4 Port Portable USB 3.0 Hub In Stock £25.29
9KRV StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
9KRV StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £31.05
Type: USB Hub
Speed: 5Gbps
Ports: 7
