StarTech.com 6 ft DisplayPort Cable with Latches - M/M
Quicklinx: FPTTWS00 Mfr#: DISPLPORT6L
Type: Video
Length: 1.8m
More than 50 in stock
£12.92 ex VAT
£15.50 inc VAT
Create high-resolution 4K x 2K connections with HBR2 support between your DisplayPort equipped devices. This DisplayPort cable provides a secure connection between your DisplayPort equipped devices and is capable of providing higher performance than either HDMI or dual-link DVI.
The DP cable supports high resolutions of up to 4K x 2K (4096 x 2160, 60Hz) with a maximum HBR2 bandwidth of 21.6Gbps, as well as optional audio support. The cable also supports Multi-Stream Transport (MST) for daisy chaining multiple monitors.
The 6-foot cable is DisplayPort (VESA) certified to support DP 1.2 specifications and ensure a high-quality, reliable connection for all of your DisplayPort devices.
StarTech.com DisplayPort 1.2 Cable w/ Latches - 6ft / 2m - HBR2 - 4K x 2K Display - Certified DP to DP Video Cable M/M (DISPLPORT6L) - DisplayPort cable - 1.8 m
DisplayPort cable
Shielded
Latched
Length
1.8 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
P/N: BOX4HDECP2, CDP2DP14B, CDP2DPHD, CDP2DPVGA, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, MOD4AVHD, MOD4AVHDBT, MST14DP123DP, ST121HDBTSC, SV211DPUA4K, SV231DPU34K, SV431DPDDUA2, SV431DPUA2, TB32DP14, TB3DK2DHV, TB3DK2DHVUE, USB32DP24K60
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
30
Plated Connector
Nickel
Latched
Length
1.8 m
Connector
20 pin DisplayPort - male
P/N: BOX4CABLE, BOX4HDECP2, CDP2DP, CDP2DP14B, CDP2DPHD, CDP2DPUCP, CDP2DPVGA, CDP2DPW, DK30A2DH, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CHDDPPD, DK31C3HDPD, DK31C3HDPDUE, DKWG30DPHPD, DKWG30DPHPDU, DPBOOST, DPPNLFM3, DPPNLFM3PW, DVI2DP2, GCMDP2DPMF, HD2DP, HD2DPVGADVI, HDMI2DP, HDVGADP2HD, MDP2DPDVHD, MDP2DPMF6IN, MOD4AVHD, MOD4AVHDBT, MST14DP123DP, MST30C2DPPD, MST30C2HDPPD, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, SP123DP, ST121HDBTSC, STDHVHDBT, SV211DPUA, SV211DPUA4K, SV231DPDDUA, SV231DPDDUA2, SV231DPU, SV231DPU34K, SV231DPUA, SV431DPDDUA2, SV431DPU3A2, SV431DPUA, SV431DPUA2, TB2DOCK4K2DP, TB32DP14, TB32DP2, TB32DP2T, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, USB32DP24K60, USB32DP4K, USB32DPES2, USB32DPPRO, USB3DDOCKFT, USB3DOCKH2DP, USB3DOCKHDPC, USB3VDOCK4DP
FPTT StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £12.24
FPTT StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £21.35
FPTT StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £11.43
Type: Video
Length: 1.8m
Stock Status: In stock
