Connect your DisplayPort monitor to a standard Mini DisplayPort source.
The MDP2DPMF6IN Mini DisplayPort to DisplayPort video cable adapter allows you to add a standard DisplayPort connection port to your existing mini Displayport equipped laptop. Easy to use and install, this cost-effective solution makes it easy for you to go from Mini DP to DP, in order to get the most from your Mini DisplayPort device.
Versatile connectivity
This adapter allows seamless connection between devices with Mini DisplayPort outputs and displays that have a 20 pin DisplayPort input, providing flexibility for various setup configurations. -
Durable construction
Constructed with high-quality PVC shielding to protect against wear and ensure consistent performance over the lifespan of the cable, making it suitable for everyday use.
- StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter (MDP2DPMF6IN) - DisplayPort cable - 15.2 cm
- DisplayPort cable
- Length
- 15.2 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DisplayPort - female
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPLPORT10L, DISPLPORT15L, DISPLPORT3L, DISPLPORT6L
- DisplayPort cable
- Shielding Material
- PVC
- American Wire Gauge (AWG)
- 32
- Length
- 15.2 cm
- Black
- Connector
- 20 pin DisplayPort - female
- RoHS
- Designed For
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.24 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.58 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £8.54 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £14.11 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.66 |
