StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable
Quicklinx: 89CQWS00 Mfr#: ICUSB2324I
Type: Serial adapter
Compatibility: PC, Mac
Interface: USB 2.0
36 In Stock
£88.60 ex VAT
£106.32 inc VAT
Add 4 DIN Rail-mountable RS232 Serial ports to any system through USB. The ICUSB2324I 4-Port Industrial USB to Serial Hub with DIN Rail Clips converts a single USB port into four RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this USB to Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the ports provided by the adapter.
  • Versatile connectivity options
    With four RS-232 ports, this adapter allows users to connect multiple serial devices simultaneously, providing flexibility for industrial and commercial applications.
  • Robust temperature operation
    This adapter can operate efficiently within a temperature range of 0°C to 55°C, making it suitable for various environments, from office settings to industrial locations.
  • Rapid data transfers
    Capable of data transfer rates up to 921.6 Kbps, this adapter ensures that large amounts of data can be transmitted quickly and reliably, essential for high-demand applications.
  • Compact and convenient design
    The wall mount and Din rail form factor make installation straightforward, while its compact nature conserves space in any setup.
  • Compliant with standards
    This product meets FCC and RoHS compliance standards, ensuring high quality and safety for users, reducing environmental impact.
StarTech.com 4 Port USB to Serial RS232 Adapter - Wall Mount - Din Rail - COM Port Retention - FTDI USB to DB9 RS232 Hub (ICUSB2324I) - serial adapter - USB 2.0 - RS-232 x 4
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 4
6.65 cm x 15 cm x 2.6 cm
450 g
RS-232
Data Transfer Rate
921.6 Kbps
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Serial adapter
External
USB 2.0
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
921.6 Kbps
USB powered
4 x RS-232 - 9 pin D-Sub (DB-9) - male
1 x USB cable (external) - 1.8 m
FCC, RoHS
Software Included
Drivers & Utilities
6.65 cm
15 cm
2.6 cm
450 g
55 °C
5 - 95%
89CQ StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.73
89CQ StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F In Stock £6.62
89CQ StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.85
89CQ StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.44
89CQ StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £88.60
89CQ StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £147.94
89CQ StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.42
89CQ StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.02
89CQ StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.35
89CQ StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.16
89CQ StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.57
89CQ StarTech.com USB to RS232 Serial Adapter In Stock £15.45
89CQ StarTech.com 16-Port USB-Serial Adapter Hub In Stock £403.98
89CQ StarTech.com 4 Port USB to Serial Hub In Stock £78.51
89CQ StarTech.com 4-Port USB to Serial Adapter In Stock £212.24
89CQ StarTech.com 8-Port USB to Serial Adapter In Stock £340.65
Compatibility: PC
Compatibility: Mac
Interface: USB 2.0
