The ICUSB232SM3 3ft USB to Serial Adapter Cable lets you connect DB9 RS232 serial devices to your Mac or PC laptop or desktop computer through an available USB port, as though the computer offered an onboard DB9M connector.
Unlike typical USB to serial converter cables where the conversion takes place at the DB9 end of the cable, the StarTech.com ICUSB232SM3 features a converter chip on the USB end. Converting at the USB source overcomes the 15ft. technical limit of USB cables, allowing for a much greater serial DB-9 extension cable (50ft.+ is possible depending on the application), should it be necessary for a given setup.
Simple to install and use, this USB to Serial adapter provides a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
Reliable connectivity
The 3 ft length of this USB to RS232 DB9 serial adapter cable provides ample reach for connecting devices without excessive cable clutter. -
Versatile compatibility
Designed for use with Mac systems, this adapter ensures that users can easily integrate their RS-232 devices with modern computing environments. -
Efficient power usage
Those looking for a simple solution will appreciate that the adapter is USB-powered, eliminating the need for additional power sources.
- StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M - serial adapter - USB 2.0 - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232
- Length
- 91.44 cm
- 42 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 1 Mbps
- Processor
- Prolific PL-2303HX
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Microsoft Windows CE 5.2, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited lifetime warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 1 Mbps
- USB powered
Processor / Memory
- Processor
- 1 x RS-232 - 9 pin D-Sub (DB-9) - male
- RoHS
- OS Required
- Length
- 91.44 cm
- 42 g
- Limited warranty - lifetime
- -20 °C
- 80 °C
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.73 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £31.73 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.85 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £25.85 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £88.60 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £151.52 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.28 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £78.51 |
StarTech.com UCB C to Serial Adapter | In Stock | £16.71 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £212.24 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £340.65 |
