StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M
CLEARANCE!
Clearance
Last Few Remaining
Quicklinx: 8PPTWS00 Mfr#: SCNM9FM2MBK
More than 50 In Stock
£4.57 ex VAT
£5.48 inc VAT
Connect your serial devices, and transfer your files. The SCNM9FM2MBK 2m DB9 Null Modem Cable features one DB9 male and one DB9 female connector, allowing you to connect a serial device to a 9-pin serial port, or transfer files directly from PC-to-PC via a serial connection.
  • Reliable connectivity
    This null modem cable features a 9-pin D-Sub connector configuration that ensures compatibility with a wide range of devices, providing a sturdy connection for uninterrupted data communication.
  • Robust construction
    With an American Wire Gauge of 28, this cable is designed for durability and reliability, ensuring effective signal transmission over extended distances.
  • Environmentally compliant
    The cable meets RoHS standards, which means it has been manufactured without hazardous substances, contributing to a safer environment while connecting devices.
  • Reduced interference
    Designed with EMI compliance, this cable minimizes electromagnetic interference, ensuring smooth data transfer, even in environments with electronic noise.
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M - DB9 Male to Female - 9 pin Null Modem Cable - 1x DB9 (M), 1x DB9 (F), Black - null modem cable - DB-9 to DB-9 - 2 m
Null modem cable
Length
2 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
9 pin D-Sub (DB-9) - male
P/N: 1P3FPC-USB-SERIAL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232PRO, ICUSB232V2, PEX2S953, PEX2S953LP
Null modem cable
American Wire Gauge (AWG)
28
Length
2 m
Connector
RoHS, EMI
