StarTech.com 4-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x4
Quicklinx: G59XWS00 Mfr#: PEXUSB314A2V2
Type: USB adapter
Compatibility: PC
Interface: PCI Express 3.0 x4
Hurry, only 2 left in stock!
£85.31 ex VAT
£102.37 inc VAT
USB 3.2 Gen 2 (10 Gbps) PCI-Express 3.0 PCIe x4 Slot USB Type-A. This PCIe USB 3.2 Gen 2 controller card installs into an available PCI-Express x4 slot in your computer and enables you to upgrade your current system by adding four SuperSpeed USB-A (10Gbps) ports. The card features dual ASM3142 controllers with up to 20 Gbps of total bandwidth shared across all 4 ports.
Add Four 10 Gbps USB Type-A Ports to Your Desktop Computer
The controller card enables you to connect four USB-A Gen 2 (10 Gbps) devices to your desktop computer. The USB-A ports are ideal for connecting USB devices such as external hard drives and solid state drives or powering and syncing your mobile devices. The USB-A ports provides up to 4.5W (5V/0.9A) of power per USB port, and are backward compatible with USB 3.2 Gen 1 (5 Gbps), and USB 2.0 (480 Mbsp) devices.
Note: USB 3.2 Gen 2 (10 Gbps) is also know as USB 3.1 Gen 2 (10 Gbps), and USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.0 and USB 3.1 (5 Gbps).
SuperSpeed USB 3.2 Gen 2 (10 Gbps) Performance
The USB 3.2 Gen 2 card features dual ASMedia ASM3142 host controllers that utilizes x4 lanes of the PCIe 2.0 bus, making the card capable of speeds up to 10 Gbps on each port, and enabling fast access to high-performance devices like NVMe drives and SSDs. The controller cards support Multiple INs to reduce bandwidth loss when multiple devices are connected, even when connected through a USB Hub (Note: The USB hub must also support this feature). The card also supports UASP for improved performance with storage devices.
Wide Installation Compatibility
This add-on card includes a full-profile installation bracket ensuring you can install it into full-profile PCIe 2.0 x4 slots. For wide platform support the card is compatible with Windows, Linux and macOS. For hassle-free installation the drivers install automatically on computers running Windows 8 or higher. Works w/USB 3.1/3.0/2.0 devices
PEXUSB314A2V2 is backed by a StarTech.com lifetime warranty and free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • Add Four 10 Gbps USB Type-A Ports to Your Desktop Computer
    The controller card enables you to connect four USB-A Gen 2 (10 Gbps) devices to your desktop computer. The USB-A ports are ideal for connecting USB devices such as external hard drives and solid state drives or powering and syncing your mobile devices. The USB-A ports provides up to 4.5W (5V/0.9A) of power per USB port, and are backward compatible with USB 3.2 Gen 1 (5 Gbps), and USB 2.0 (480 Mbsp) devices. Note: USB 3.2 Gen 2 (10 Gbps) is also know as USB 3.2 Gen 2 (10 Gbps), and USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.2 Gen 1 and USB 3.2 (5 Gbps).
  • SuperSpeed USB 3.2 Gen 2 (10 Gbps) Performance
  • Wide Installation Compatibility
    This add-on card includes a full-profile installation bracket ensuring you can install it into full-profile PCIe 2.0 x4 slots. For wide platform support the card is compatible with Windows, Linux and macOS. For hassle-free installation the drivers install automatically on computers running Windows 8 or higher. Works w/USB 3.2/3.0/2.0 devices PEXUSB314A2V2 is backed by a StarTech.com lifetime warranty and free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
StarTech.com 4-Port USB PCIe Card - 10Gbps USB 3.1/3.2 Gen 2 Type-A PCI Express Expansion Card - 2 Controllers - 4xUSB - Windows/Mac/Linux - USB adapter - PCIe 3.0 x4 - USB 3.1 Gen 2 x 4
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express 3.0 x4
PCI Specification Revision
PCIe 3.0
Ports
USB 3.1 Gen 2 x 4
2 cm x 12.5 cm x 8.5 cm
79 g
USB 3.1 Gen 2
Data Transfer Rate
10 Gbps
ASMedia ASM1142
USB 3.1, xHCI 1.1
Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
USB adapter
Plug-in card
PCI Express 3.0 x4
PCIe 3.0
Ports
USB 3.1 Gen 2 x 4
Wired
USB 3.1 Gen 2
Data Transfer Rate
10 Gbps
UASP
USB 3.1, xHCI 1.1
Processor / Memory
ASMedia ASM1142
4 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x SATA 3Gb/s - 15 pin Serial ATA power , 1 - 4 PIN internal power
FCC, RoHS, WEEE
2 cm
12.5 cm
8.5 cm
79 g
-20 °C
60 °C
5 - 85% (non-condensing)
G59X StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.42
G59X StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.41
G59X StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.17
G59X StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.17
G59X StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £46.54
G59X StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £60.78
G59X StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £25.78
G59X StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.60
G59X StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £8.79
G59X StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £8.69
G59X StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £37.70
G59X StarTech.com 2-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x2 In Stock £24.16
G59X StarTech.com 1-Port USB 3.2 Gen 2x2 PCIe Card - USB-C SuperSpeed 20Gbps PCI Express 3.0 x4 In Stock £39.65
G59X StarTech.com 5-Port USB PCIe Card In Stock £47.76
G59X StarTech.com 4-Port USB PCIe Card In Stock £99.15
G59X StarTech.com 5-Port USB PCIe Card, 10Gbps In Stock £55.27
G59X StarTech.com 4-Port USB-A PCIe Card, 5Gbps In Stock £78.58
G59X StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £196.98
G59X StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £200.08
Type: USB adapter
Compatibility: PC
