StarTech.com 4-Port USB-C 10Gb PCIe Card
Quicklinx: J7YTWS00 Mfr#: P10Q4C-USB-CARD-LP
£200.08 ex VAT
£240.09 inc VAT
Expand a desktop or server's USB connectivity with four external USB Type-C 10Gbps ports using this PCI Express 3.0 expansion card. It provides up to 5V 3A (15W) per USB-C port for charging and syncing devices. The high bandwidth is ideal for large file transfers, high-resolution photo/video editing on external storage, and high-speed USB network adapters. If the motherboard power is insufficient, a built-in SATA power connector can supply additional power. The card is plug-and-play in Windows, Linux, and macOS and is compatible with PCI Express 3.0 x4, x8, and x16 slots. The PCIe card ships with a low-profile bracket, and a standard profile bracket is included for maximum system compatibility.
  • Dedicated USB Controllers
    Traditional single-controller USB cards share bandwidth across all ports. With its four independent USB controllers, this USB-C expansion card enables each port to achieve up to 10Gbps, reducing bottlenecks and increasing data throughput.
  • USB 3.2 Gen 2 (10Gbps) Performance
    The high bandwidth makes the card ideal for transferring large files, real-time editing of high-resolution photos and videos on external storage, off-loading media from mobile devices, using high-resolution video capture devices, tethered photography equipment, or high-speed USB network adapters like 10G Ethernet copper or fiber adapter.
  • Charge and Sync USB Devices
    This USB PCI Express card can provide up to 5V 3A (15W) per USB-C port, enabling sync and charge of portable devices. If the motherboard can't supply enough power, a built-in SATA power connector can supply additional power to the card.
  • Compatibility
    The PCI Express USB card is plug-and-play in most major operating systems, including Windows, macOS, and Linux. The card is compatible with PCI Express 3.0 and x4, x8, and x16 slots. The USB expansion card also ships with a pre-installed low-profile bracket and includes a standard profile bracket for maximum compatibility.
StarTech.com 4-Port USB Type-C PCIe Card, USB-C 10Gb, 4x Controllers, TAA - USB adapter - PCIe 3.0 x4 - USB-C 3.2 Gen 2 x 4 - TAA Compliant
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
Ports
USB-C 3.2 Gen 2 x 4
5.62 cm x 14 cm x 7.92 cm
100 g
USB-C
Data Transfer Rate
10 Gbps
USB 1.1, USB 2.0, USB 3.0, USB 3.1, USB 3.2
Linux 2.6.31 or later, Microsoft Windows 10 / 11, Microsoft Windows Server 2019/2022 Standard, Apple macOS Sequoia 15.x, Apple macOS Sonoma
TAA Compliant
USB adapter
PCI Express 3.0 x4
Ports
USB-C 3.2 Gen 2 x 4
Wired
USB-C
Data Transfer Rate
10 Gbps
UASP, built-in SATA power connector
4 x USB-C - 24 pin USB-C - female (external) , 1 x SATA power - 15 pin Serial ATA power (internal)
Low-profile bracket, standard bracket
WEEE
TAA Compliant
5.62 cm
14 cm
7.92 cm
100 g
85 °C
20 - 80% RH (non-condensing)
J7YT StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £53.70
J7YT StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £41.59
J7YT StarTech.com 3ft USB C Cable 10Gbps Gen2 In Stock £15.44
J7YT StarTech.com 3m Active USB-C Cable, USB 3.2 In Stock £46.67
J7YT StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £196.98
