StarTech.com 4-Port USB PCIe Card
Quicklinx: GFHZWS00 Mfr#: PEXUSB312A2C2V
Wired / Wireless: Wired
Protocol: USB 2.0, SuperSpeed USB 3.0, USB 3.1, USB 3.2 Gen 1 + 1 more
Form Factor: Plug-in card
Compatibility: [N/A]
Type: USB adapter
£101.62 ex VAT
£121.94 inc VAT
2x USB 3.2 Gen 2x1 (10Gbps) Type-A - 2x USB 3.2 Gen 2x1 (10Gbps) Type-C.
  • Work faster and prepare for the future
    This versatile PCI Express combo card leverages the performance potential of USB 3.2 Gen 2x1 (10Gbps) to help you work faster. The USB ports offer a data throughput of up to 10Gbps, so you can spend less time waiting for file transfers to complete or for access to your external peripherals.
  • Connect different types of USB devices
    Now you can easily add a variety of types and speeds (generations) of USB ports to your desktop or server, using a single adapter card. The card features: • Two external USB-C port (USB 10Gbps) • Two external USB-A ports (USB 10Gbps) With a range of port types, the card lets you bridge the gap between devices that use different connectors. You can simultaneously connect and access USB Type-A and USB Type-C devices, while using only a single PCI Express expansion slot. By adding two types of USB ports in one combo card, you can free up space in your PC case, and eliminate the nuisance of having different cards for different USB devices.
  • Connect your older USB devices
    Connecting your older peripherals isn't a problem. This 4-port USB 3.2 card is backward compatible with legacy USB 3.0, 2.0 and 1.1 devices, so you can eliminate the added expense and aggravation of purchasing new devices. USB 3.0 is also known as USB 3.2 Gen 1x1 (5Gbps) and USB 3.1 Gen 1 (5Gbps). The PEXUSB312A2C2V is backed by a StarTech.com 2-year warranty and free lifetime technical support. Note: The card does not support DP alt mode or USB Power Delivery.
StarTech.com 4-Port USB PCIe Card, 10Gbps USB PCI Express Expansion Card w/ 2 Controllers, 2x USB-C & 2x USB-A ports (USB 3.2/3.1 Gen 2), USB/USB-C PCI-e Card, Full Profile Brackets - USB PCIe Add-On Card (PEXUSB312A2C2V) - USB adapter - PCIe 3.0 x4 - USB-C 3.2 Gen 2 x 2 + USB-C 3.2 Gen 2 x 2
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express 3.0 x4
Ports
8.5 cm x 11.2 cm x 2.2 cm
80 g
USB 2.0, USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1
Data Transfer Rate
10 Gbps
ASMedia
Red
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS Ventura 13.0
USB adapter
Plug-in card
PCI Express 3.0 x4
Ports
Wired
USB 2.0, SuperSpeed USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1
Data Transfer Rate
10 Gbps
UASP
Processor / Memory
ASMedia
2 x USB 3.2 Gen 2 - 9 pin USB Type A , 2 x USB 3.2 Gen 2 - 24 pin USB-C , 1 x SATA power - 15 pin Serial ATA power (internal)
Low-profile bracket
MTBF
1,677,495 hours
FCC, RoHS, WEEE, UASP (USB Attached SCSI Protocol)
Red
8.5 cm
11.2 cm
2.2 cm
80 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
141 g
70 °C
15 - 90% (non-condensing)
GFHZ StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
GFHZ StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £18.98
GFHZ StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
GFHZ StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
GFHZ StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
GFHZ StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £38.05
GFHZ StarTech.com 2-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x2 In Stock £24.39
GFHZ StarTech.com 4-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x4 In Stock £87.44
GFHZ StarTech.com 1-Port USB 3.2 Gen 2x2 PCIe Card - USB-C SuperSpeed 20Gbps PCI Express 3.0 x4 In Stock £40.64
GFHZ StarTech.com 5-Port USB PCIe Card In Stock £48.96
GFHZ StarTech.com 5-Port USB PCIe Card, 10Gbps In Stock £56.66
GFHZ StarTech.com 4-Port USB-A PCIe Card, 5Gbps In Stock £80.54
GFHZ StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £201.91
GFHZ StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £206.84
Protocol: USB 2.0
Protocol: SuperSpeed USB 3.0
Protocol: USB 3.1
Protocol: USB 3.2 Gen 1
Protocol: USB 3.2 Gen 2
Type: USB adapter
