StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels
Quicklinx: 964KWS00 Mfr#: PEXUSB3S44V
Type: USB adapter
Compatibility: PC
Interface: PCI Express x4
37 in stock
£71.38 ex VAT
£85.65 inc VAT
Add four USB 3.0 ports with four independent channels, LP/SATA power, and charging support to your PC through a PCI Express slot. The PEXUSB3S44V 4-Port PCI Express USB 3.0 Card lets you add four, dedicated 5 Gbps USB 3.0 ports to your PCIe x4-enabled PC. This independent port architecture improves USB 3.0 performance by transferring data on four individual channels to your computer, giving you faster file transfers.
When multiple devices are connected, traditional single bus USB 3.0 cards share your maximum bandwidth between all ports. By employing four host controller chipsets, each port operates on a separate independent transmission channel. Dedicating up to 5 Gbps to each USB port reduces performance bottlenecks, and effectively quadruples your total available to bandwidth to 20 Gbps.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
For high-power USB devices, this PCIe USB 3.0 card includes an optional SATA or LP4 power connector to connect to your system power supply and deliver up to 900mA of power per port to USB 3.0 bus-powered devices (500mA for USB 2.0). The USB 3.0 card also supports USB Battery Charging Specification 1.2 (Apple Mode only), letting you charge compatible Apple devices (iPhones and iPads) faster than a standard USB 3.0 port.
The controller card is compliant with USB 3.0 standards while offering backward compatibility with existing USB 2.0 / 1.1 devices. For added versatility, the USB 3.0 PCIe card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
UASP is supported in Windows 8, 8.1, Server 2012 and Linux kernel 2.6.37 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 4 Port USB 3.0 PCIe Card w/ 4 Dedicated 5Gbps Channels - UASP - SATA / LP4 Power - USB PCI Express Card Adapter (PEXUSB3S44V) - USB adapter
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
Ports
USB 3.0 x 4
6.7 cm x 12.1 cm x 1.9 cm
90 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
4 x uPD720202 - NEC
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 2.6.31 - 4.11.x LTS versions only
USB adapter
Plug-in card
PCI Express x4
Ports
USB 3.0 x 4
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Processor / Memory
4 x uPD720202 - NEC
4 x USB 3.0 - 9 pin USB Type A (external)
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
6.7 cm
12.1 cm
1.9 cm
90 g
50 °C
5 - 85%
964K StarTech.com 10 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £9.33
964K StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.72
964K StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £5.03
964K StarTech.com 4 Port Black SuperSpeed USB 3.0 Hub In Stock £27.00
964K StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £73.16
964K StarTech.com 3m USB 3.0 Active Extension Cable - M/F In Stock £55.50
964K StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £57.89
964K StarTech.com 10m USB 3.0 Active Extension Cable - M/F In Stock £82.01
964K StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £30.85
964K StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter In Stock £28.24
964K StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £63.98
964K StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £71.38
Type: USB adapter
Compatibility: PC
Price Range Ex VAT: 50 - 100
