StarTech.com 3m USB 3.0 Active Extension Cable - M/F
Quicklinx: 80HRWS00 Mfr#: USB3AAEXT3M
Length: 3m
More than 50 In Stock
£67.37 ex VAT
£80.84 inc VAT
Extend the distance of a USB 3.0 device an additional 3 meters. The USB3AAEXT3M, 3-meter Active USB 3.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 3.0 devices of up to 3-meters (10-feet). An all-in-one cable for overcoming distance restrictions as well as power source limitations; the active USB 3.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the typical length limits of standard USB cables. Up to 4 of these cables can be daisy-chained together, allowing the connection to be extended a total of 12-meters. If necessary, the USB device can be powered from a wall outlet, using the Universal AC power adapter provided with the cable. The USB3AAEXT3M extension cable (USB Extender) supports high speed USB 3.0 transfer rates of up to 5Gbps.
  • Reliable Signal Regeneration
    The active design of this USB extension cable allows for effective signal regeneration, which prevents data loss over extended distances. Users can connect devices with confidence, knowing their data transfer will remain intact.
  • Broad Compatibility
    This cable supports a variety of standards, including USB 3.0, USB 2.0, and USB, making it suitable for a wide array of devices. The male to female configuration allows for easy connections to peripherals.
  • Durable Construction
    Featuring nickel-plated connectors, this cable offers enhanced durability and resistance to wear. This ensures a longer lifespan and consistent connectivity, even with frequent use.
  • Length for Convenience
    At 3 m long, this extension cable provides ample length for users to position their devices conveniently without the limitation of short cables. This flexibility enhances usability in various settings.
  • Environmentally Compliant
    With compliance to FCC and RoHS standards, this cable meets important safety and environmental regulations. Users can feel assured they are using a product designed with responsibility in mind.
StarTech.com 3m USB 3.0 Active Extension Cable - M/F - 3m USB 3.0 Extension Cable - USB 3.0 repeater Cable (USB3AAEXT3M) - USB extension cable - USB Type A to USB Type A - 3 m
USB extension cable
Active cable (signal regeneration)
Length
3 m
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type A - female
USB / USB 2.0 / USB 3.0
P/N: PEXUSB3S42V, PEXUSB3S44V, ST7300USB3B, SVA5H2NEUA, USB3SAA3MBK
USB extension cable
Plated Connector
Nickel
Length
3 m
Connector
USB / USB 2.0 / USB 3.0, FCC, RoHS
80HR StarTech.com 3m USB 3.0 Active Extension Cable - M/F In Stock £67.37
80HR StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £81.57
80HR StarTech.com 10m USB 3.0 Active Extension Cable - M/F In Stock £110.10
80HR StarTech.com 6in USB 3.0 Extension Cable In Stock £5.27
80HR StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.17
80HR StarTech.com DC Power Adapter - 5V, 2A In Stock £9.67
Length: 3m
