This Thunderbolt 3 network adapter connects your Thunderbolt 3 enabled device to a 10GbE network via a PCIe expansion chassis. This Thunderbolt 3 10GbE NIC adapter lets you connect a Thunderbolt 3 device to a 10GbE network. The adapter combines the Thunderbolt 3 technology of TB31PCIEX16 with the 10GbE dual-fiber connection of PEX10GSFP4I (Intel XL710 chipset). The assembled adapter features one DisplayPort output, one additional Thunderbolt 3 port, and four open 10GbE SFP+ slots.
The Thunderbolt 3 10GbE NIC adapter is the perfect solution for your mission-critical operations. The network adapter supports 802.1Q VLAN tagging for better network management, 802.3ad link aggregation for greater network speeds, redundancy support for network reliability, and four 10G fiber connections through open SFP+ fiber slots, to build a custom setup.
Requiring only a Phillips type screwdriver and your choice of SFP, this Thunderbolt 3 10GbE NIC adapter can be assembled and connected in minutes.
The Thunderbolt 3 chassis not only pairs well with the 10G fiber network card, the card can be swapped for any PCIe card to help support other functionality and performance. With the extra TB3 port and DP output built into the chassis, you will always have the ability to hook up extended displays to multitask effortlessly.
- StarTech.com Thunderbolt 3 to 10GbE Fiber Network Chassis 4 Port - network adapter - PCIe 3.0 x8 - 10 Gigabit SFP+ x 4
- Network adapter
- Form Factor
- Plug-in card
- Bundled with
- Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
- Interface (Bus) Type
- PCI Express 3.0 x8
- PCI Specification Revision
- PCIe 3.0
- Ports
- Cabling Type
- Ethernet 10GBase-LR, Ethernet 10GBase-SR
- Data Link Protocol
- 10GbE
- Data Transfer Rate
- 10 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- Intel XL710
- IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3q
- System Requirements
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- Bundled with
- PCIe 3.0
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 10 Gbps
- Capacity
- Status Indicators
- Link/activity
- Flow control, full duplex capability, Jumbo Frames support, Link Aggregation, VLAN Tagging
Processor / Memory
- Processor
- Intel XL710
- 4 x 10GBase-SR/LR - SFP+ - female
- Cables Included
- 1 x Thunderbolt 3 / USB-C cable (external) - 50 cm
- FCC, RoHS, WEEE
- OS Required
- Limited warranty - 2 years
- 5 °C
- 20 - 80%
StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter | In Stock | £49.12 |
StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length | In Stock | £327.11 |
StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter | In Stock | £19.72 |
StarTech.com PCI Express to 4 Slot PCI Expansion System | In Stock | £376.57 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £34.48 |
StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 | In Stock | £110.54 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels | In Stock | £46.45 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £80.54 |
StarTech.com USB-C to VGA Adapter | In Stock | £22.16 |
StarTech.com 4-Port Gigabit NIC - PCIe | In Stock | £151.83 |
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £295.64 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £21.26 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £18.76 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £22.59 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £24.76 |
