This 4-port HDMI KVM switch lets you control four HDMI computers with a single mouse, keyboard and monitor.
Convenient and cost-effective USB 3.0 peripheral sharing
This 4-port KVM switch offers two USB 3.0 ports, as well as four HID keyboard and mouse ports, so you can share peripheral devices between each computer and avoid the cost of separate equipment. The USB 3.0 hub automatically switches your connected devices to the selected computer, saving you the hassle of disconnecting and reconnecting peripherals. -
Complete multimedia capability
Along with dual video capability, this KVM switch features auxiliary 3.5 mm dual-channel bi-directional audio ports. This independent analog audio lets you share your analog audio devices such as speakers or a microphone between each of your connected computers, giving you complete multimedia control of your systems.
- StarTech.com StarTech.com 4-Port Dual Monitor HDMI KVM Switch with Audio & USB 3.0 hub - 4K 30Hz - 4 PC Mac Computer KVM Switch Box for HDMI Display (SV431DHD4KU) - KVM / audio / USB switch - 4 ports - rack-mountable
- Enclosure Type
- Rack-mountable
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- Power
- AC 120/230 V
- 22 cm x 13 cm x 6.3 cm
- 1.2 kg
- Black
- 2-year warranty
- Enclosure Type
- Rack-mountable
- Subtype
- KVM
- Ports
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 30 Hz
- Status Indicators
- Status
- 4 x USB 3.0 Type B , 4 x USB 1.1 Type A , 10 x HDMI , 2 x USB 3.1 , 5 x audio mini-jack
- Power Device
- External power adapter
- Power Provided
- 1.5 A
- Voltage Required
- AC 120/230 V
- 18 Watt
- Black
- Included Accessories
- 4 rubber feet
- 22 cm
- 13 cm
- 6.3 cm
- 1.2 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
- Humidity Range Storage
- 0 - 80%
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £243.20 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £74.93 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £22.12 |
StarTech.com 2-port Dual VGA KVM Switch | In Stock | £67.05 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £245.82 |
StarTech.com 2 Pt DisplayPort KVM | In Stock | £287.20 |
