This 2-port KVM switch combines 4K (60Hz) digital display capabilities with control of two connected computers.
The DisplayPort KVM switch supports resolutions up to 4K at 60Hz.Itdrivesone large monitor at the full 4K resolution or, using an MST adapter, can drive various DisplayPort multi-display setups totaling 4Kif you need to maximize viewing space. With support for digital audio (with supporting displays and sources)and separate 3.5 mm stereo audio, the DisplayPort 1.2 KVM switch delivers full audio compatibility.
The integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners.
While supporting Windows, this DP KVM switch is also compatible with Mac and Linux operating systems.
The front-panel pushbuttons make it easy to switch between systems and activate the auto scan feature. The hotkey functionality makes accessing each system quickly, while a buzzer sound confirms the switch.
StarTech.com offers a wide selection of high-quality KVM switches and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice, and monitors.
4K60 picture and full audio support
The DisplayPort KVM switch supports resolutions up to 4K at 60 Hz. It drives one large monitor at the full 4K resolution or, using an MST adapter, can drive various DisplayPort multi-display setups totaling 4K if you need to maximize viewing space. With support for digital audio (with supporting displays and sources) and separate 3.5 mm stereo audio, the DisplayPort 1.2 KVM switch delivers full audio compatibility. -
Integrated USB hub
The integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners. -
Easy to operate
- StarTech.com 2 Port DisplayPort KVM Switch, 4K 60Hz, Single Display, Dual Port UHD DP 1.2 USB KVM Switch with Integrated USB 3.0 Hub and Audio, Dell, HP, Apple, Lenovo, TAA Compliant - Keyboard/Video/Mouse Switch (SV231DPU34K) - KVM / audio / USB switch - 2 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- 4K resolution support, MST support
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 60 Hz
- Status Indicators
- Status
- 1 x DisplayPort output , 2 x DisplayPort input , 1 x audio output mini-jack , 2 x audio input mini-jack , 4 x keyboard (USB) / mouse (USB) Type A , 2 x USB 3.0 Type B , 2 x USB 3.0 Type A
- Power Device
- External power adapter
- Included Accessories
- 4 rubber feet
- DisplayPort 1.2
- TAA Compliant
- Localisation
- Limited warranty - 2 years
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £246.14 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £230.07 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £22.32 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.58 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £2.97 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £39.71 |
StarTech.com MST Hub - 4-Port DisplayPort | In Stock | £66.85 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.29 |
StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £351.01 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £251.98 |
StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz | In Stock | £336.44 |
StarTech.com 4PT Dual DP KVM Switch 4K60 | In Stock | £583.16 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.66 |
StarTech.com 2 Port USB C KVM Switch | In Stock | £77.13 |
StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch | In Stock | £360.65 |
StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch | In Stock | £461.44 |
StarTech.com 2 Port Hybrid USB-C KVM Switch | In Stock | £34.40 |
StarTech.com 2-Port DP KVM Switch, 8K 60Hz | In Stock | £305.16 |
StarTech.com 4-Port DP KVM Switch, 8K 60Hz | In Stock | £378.68 |
