StarTech.com 2 Port Dual DP KVM Switch - 4K
Quicklinx: CRYPWS00 Mfr#: SV231DPDDUA2
Type: KVM / audio / USB switch
Ports: 2
Connectivity: KVM
15 In Stock
£259.12 ex VAT
£310.94 inc VAT
This dual DisplayPort KVM switch combines next-generation digital display standards with seamless KVM control. The 2-port KVM switch features audio and USB peripheral support along with dual-display capability, which makes it easy to create a multimedia workstation that can switch between two dual-head or twin DisplayPort systems.
StarTech.com 2-Port DisplayPort KVM Switch - Dual-Monitor - 4K 60 - with Audio & USB Peripheral Support - DP 1.2 - USB Hub (SV231DPDDUA2) - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
4K resolution support
AC 120/230 V / DC 12 V 0.6 A
16.1 cm x 10 cm x 5.75 cm
1.2 kg
Australia, Japan, New Zealand, North America, United Kingdom, Europe
P/N: SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
6 x DisplayPort , 3 x audio / headphones mini-jack , 3 x microphone input mini-jack , 4 x USB 2.0 Type A , 2 x USB Type B
External power adapter
Electric Current Required
0.6 A
4 rubber feet
FCC, RoHS, WEEE, RCM
16.1 cm
10 cm
5.75 cm
1.2 kg
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
CRYP StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £253.13
CRYP StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.57
CRYP StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £191.45
CRYP StarTech.com DisplayPort USB KVM Switch In Stock £292.14
CRYP StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.05
CRYP StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
CRYP StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.83
CRYP StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.11
CRYP StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
CRYP StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.63
CRYP StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £360.98
CRYP StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £259.12
CRYP StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz In Stock £345.98
CRYP StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £494.89
CRYP StarTech.com 2 Pt DisplayPort KVM In Stock £302.73
CRYP StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £84.89
CRYP StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £95.65
CRYP StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.12
CRYP StarTech.com 2 Port USB C KVM Switch In Stock £91.76
CRYP StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £95.09
CRYP StarTech.com 2-Port Dual-Monitor KVM Switch In Stock £314.68
Ports: 2
Connectivity: KVM
