StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub
Quicklinx: 6LCZWS00 Mfr#: SV431DDVDUA
£249.28 ex VAT
£299.13 inc VAT
The SV431DDVDUA 4-port DVI VGA dual monitor KVM switch lets you control 4 Dual Display computers using a single USB mouse and keyboard peripheral set.
This dual view KVM switch provides 1 VGA and 1 DVI-I port per computer connection for high-resolution video, as well as audio switching capability between connected computers.
The DVI/VGA KVM switch features an integrated 2-port USB hub that allows USB 2.0 peripherals to be shared between connected computers, and offers a compact design with a rugged metal chassis for durable performance.
While both DVI-I (analog) and DVI-D (digital) are supported by the KVM, source PCs must output the same signal for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
  • Efficient management of multiple devices
    The 4 Port DVI VGA Dual Monitor KVM Switch allows a single user to control up to four connected devices, enabling seamless transitions between systems without the need for multiple keyboards and mice.
  • High video resolution support
    This KVM switch supports a maximum video resolution of 1920 x 1440, ensuring that users can enjoy sharp and vibrant visuals for both work and entertainment.
  • Convenient USB hub integration
    Featuring a built-in 2-port USB 2.0 hub, this device provides users with extra connectivity for various peripherals, minimizing clutter and enhancing workflow.
  • Versatile operating temperatures
    With an operating temperature range of 0°C to 40°C, this KVM switch can function effectively in different environments, making it reliable for both professional and personal use.
  • Compliant with standards
    Having received FCC and RoHS compliance, this product meets necessary safety and environmental guidelines, assuring users of its quality and reliability.
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio and USB 2.0 Hub (SV431DDVDUA) - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, HDCP compliant
22 cm x 13 cm x 6 cm
1.2 kg
3-year warranty
P/N: IM12D1500P, SV431RACK, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6, USBVGA4N1A10, USBVGA4N1A6
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
1 x VGA HD-15 , 1 x DVI-D , 4 x USB 2.0 Type A , 2 x audio mini-jack , 4 x VGA HD-15 , 4 x DVI-D , 4 x audio mini-jack , 4 x USB 2.0 Type B
External power adapter
FCC, RoHS
22 cm
13 cm
6 cm
1.2 kg
Limited warranty - 3 years
