StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display
Quicklinx: DKFQWS00 Mfr#: SV431DHD4KU
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
Hurry, only 3 left in stock!
£481.26 ex VAT
£577.51 inc VAT
This 4-port HDMI KVM switch lets you control four HDMI computers with a single mouse, keyboard and monitor.
  • Convenient and cost-effective USB 3.0 peripheral sharing
    This 4-port KVM switch offers two USB 3.0 ports, as well as four HID keyboard and mouse ports, so you can share peripheral devices between each computer and avoid the cost of separate equipment. The USB 3.0 hub automatically switches your connected devices to the selected computer, saving you the hassle of disconnecting and reconnecting peripherals.
  • Complete multimedia capability
    Along with dual video capability, this KVM switch features auxiliary 3.5 mm dual-channel bi-directional audio ports. This independent analog audio lets you share your analog audio devices such as speakers or a microphone between each of your connected computers, giving you complete multimedia control of your systems.
StarTech.com StarTech.com 4-Port Dual Monitor HDMI KVM Switch with Audio & USB 3.0 hub - 4K 30Hz - 4 PC Mac Computer KVM Switch Box for HDMI Display (SV431DHD4KU) - KVM / audio / USB switch - 4 ports - rack-mountable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
4 x KVM / audio / USB
AC 120/230 V
22 cm x 13 cm x 6.3 cm
1.2 kg
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 30 Hz
Status Indicators
Status
4 x USB 3.0 Type B , 4 x USB 1.1 Type A , 10 x HDMI , 2 x USB 3.1 , 5 x audio mini-jack
External power adapter
Power Provided
1.5 A
AC 120/230 V
18 Watt
4 rubber feet
22 cm
13 cm
6.3 cm
1.2 kg
0 - 80%
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
Humidity Range Storage
0 - 80%
DKFQ StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £249.28
DKFQ StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £131.32
DKFQ StarTech.com DisplayPort USB KVM Switch In Stock £230.07
DKFQ StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.32
DKFQ StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £251.98
DKFQ StarTech.com 2 Pt DisplayPort KVM In Stock £294.39
Connectivity: KVM
Ports: 4
