Turn a 3.5" SATA Hard Drive into a UASP-supported USB 3.0 External Hard Drive. The S3510SMU33 USB 3.0 hard drive enclosure enables you to connect a 3.5in SATA hard drive through an available USB port.
With support for UASP, the enclosure performs up to 70% faster than conventional USB 3.0, when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
The HDD enclosure offers a versatile solution for increasing the storage/backup capabilities of your computer, with support for SATA I/II/III hard drives at capacities of up to 4TB. Plus, the enclosure features high-quality aluminum construction and a stylish silver design that looks great in any application.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
- StarTech.com 3.5in Silver Aluminum USB 3.0 External SATA III SSD / HDD Enclosure with UASP - Portable USB 3 3.5" SATA Hard Drive Enclosure (S3510SMU33) - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Silver
- Expansion Bays
- 1 x internal - 3.5"
- Hard Drive Form Factor Compatibility
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- Product Material
- Plastic, aluminium
- Power Source
- Included AC adapter
- Power
- AC 120/230 V
- System Requirements
- Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 11.54 cm x 19.15 cm x 3.14 cm
- 319.8 g
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA, USBDUP15, USBDUPE115, USBDUPE17
- 3.5"
- Host Bus
- USB 3.0
- Product Material
- Silver
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Hard drive
- 1
- Processor
- ASMedia ASM1053E
- Bays
- 1 x SATA 6Gb/s - SATA power
- Connections
- 1 x USB 3.0 - 9 pin USB Type A
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - external - 1 m
- LED indicator, tested with up to 4TB 7200 RPM hard drives
- Mounting Kit
- Included
- Plug and Play, FCC, RoHS
- Power Source
- Power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- Limited warranty - 2 years
- 11.54 cm
- 19.15 cm
- 3.14 cm
- 319.8 g
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £28.32 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £35.47 |
StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power | In Stock | £54.71 |
StarTech.com 1m USB 3 Cable Right Angle BK | In Stock | £6.81 |
StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £10.30 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £8.07 |
StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power | In Stock | £11.59 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £9.09 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £27.56 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.96 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £35.55 |
