This USB-C to SATA adapter cable gives you fast and easy access to the data on your 2.5 in./3.5 in. solid-state drives and hard drives. The adapter cable lets you connect your USB-C enabled laptop or desktop computer directly to a SATA drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10Gbps). It's the ideal accessory for your Dell XPS, MacBook, Chromebook or other USB Type-C enabled device.
The USB-C to SATA adapter cable lets you quickly swap your drives. You can copy or retrieve data from your 2.5 in. or 3.5 in. SATA drive, with no additional accessories required.
The tool-free adapter cable is ideal for IT technicians who need fast access to SATA drives. It's the perfect solution for data migration, drive cloning, and data backup or recovery applications, providing the fast performance of USB 3.1 Gen 2. You can also operate multiple adapters at the same time, when you need simultaneous access to many drives.
USB 3.1 Gen 2 gives you greater bandwidth and speed, with rates of up to 10Gbps - twice the speed of USB 3.0 (also known as USB 3.1 Gen 1). It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The compact, lightweight design of the USB-C to SATA adapter provides easy portability. The adapter features an integrated 1 m cable, so you never have to worry about forgetting to bring your connector cable with you.
You can connect easily to a 2.5 in. solid-state drive or hard drive, using USB power, with no external power required. A universal power adapter is included for use when connecting to your 3.5 in. drives or for any 2.5 in. drives that may require additional power.
Convenient and versatile drive access
The USB-C to SATA adapter cable lets you quickly swap your drives. You can copy or retrieve data from your SATA drive, with no additional accessories required. The tool-free adapter cable is ideal for IT technicians who need fast access to SATA drives. It's the perfect solution for data migration, drive cloning, and data backup or recovery applications, providing the fast performance of USB 3.1 Gen 2. You can also operate multiple adapters at the same time, when you need simultaneous access to many drives. -
Harness the speed of USB 3.1 Gen 2
USB 3.1 Gen 2 gives you greater bandwidth and speed. It lets you leverage the high performance of the SSDs and hard drives, while alleviating bottlenecks in your data transfers. -
Portable and easy to use
The compact, lightweight design of the USB-C to SATA adapter provides easy portability. The adapter features an integrated cable, so you never have to worry about forgetting to bring your connector cable with you. You can connect easily to a solid-state drive or hard drive, using USB power, with no external power required.
- StarTech.com USB C to SATA Adapter Cable - for 2.5 / 3.5" SATA Drives - 10Gbps - USB 3.1 - SATA to USB Adapter - External Hard Drive Cable (USB31C2SAT3) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage controller - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Power
- AC 120/230 V
- 2.5 cm x 8.7 cm x 2 cm
- 80 g
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- 2.5", 3.5"
- Host Bus
- USB 3.1 (Gen 2)
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Processor
- ASMedia ASM1351
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 24 pin USB-C
- Cables Included
- 1 x SuperSpeed USB-C cable - integrated - 1 m
- LED indicator, UASP transfer protocol, S.M.A.R.T. support, TRIM support
- FCC, RoHS, UASP (USB Attached SCSI Protocol)
- Power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
- 2.5 cm
- 8.7 cm
- 2 cm
- 80 g
- 0 °C
- 60 °C
- 0 - 80%
- Designed For
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.30 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.07 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.51 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £17.99 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £25.78 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £52.38 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £80.75 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £26.81 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.71 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £34.51 |
